Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 03-26-2008, 11:32 AM
hydrospin01 is on a distinguished road
Question VB6,VB.net,VB script,What one???
hello all,
I've been using Macro's for programing families of parts but would like to start using Visual basic instead, Is there a specific version of VB I should use for CNC? What one works best?
Old 03-26-2008, 01:07 PM
ProProcess is on a distinguished road
VB6 is no longer supported.
You can get VB.NET 2008 Express free and would be a great place to start.
I'm not 100% on VBScript.
However, macro for families of parts is still very good.
One program for many parts makes Rev changes less of an issue.
Change one program vs changing many.
Just MHO.
Good luck.
Old 03-26-2008, 05:11 PM
Kiwi is on a distinguished road
I use VB6 and find it great. Never had a problem because its not supported by MS.
I understand VB.net is much harder to learn.
Old 03-26-2008, 05:20 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
I wouldn't say .net is harder to learn, just structured differently than vb6. VBScript is more geared for web applications...
Either will work fine for making gcode output.
Paul
Old 03-26-2008, 05:30 PM
ger21's Avatar
If you don't know either, than probably not. But for the occasional VB user, I think .net is definitely harder. Probably due to having to unlearn the VB stuff.
Old 03-26-2008, 05:36 PM
Smile
I think i'll go with VB .Net then.
thank you all.
Old 03-28-2008, 08:36 PM
keithorr is on a distinguished road
thank you all.
I learned vb.net as a beginner with no previous experience using the express version. Much online help is available. I made an application to control an industrial 6 axis robot with voice commands. It took a while to learn but I was incorporating a lot for a first time project; text parsing, logic, command flow, i/o and the voice interface.
Old 04-29-2008, 09:23 AM
jeep534 is on a distinguished road
I am a Block one square one beginner, where would you recommend I look online for Help
archie =) =) =)
Old 04-29-2008, 01:52 PM
Originally Posted by jeep534 View Post
I am a Block one square one beginner, where would you recommend I look on-line for Help
archie =) =) =)
same here. I started with the tutorials in vb.net. I add parts to my application in separate projects rather than screw up my main effort. I used the on-line ask a question feature that led to a lot of different examples. After a while I started to see patterns in the coding. I'd also google key words as a lot of clues are outside the msdn scope.
Learning to parse text files to recalculate axis values was the hardest.
There are many sample projects available that demonstrate different aspects.
Old 04-29-2008, 06:02 PM
A simple program called AWK or MAWK or GAWK is excellent for this purpose.
Old 04-30-2008, 05:10 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
I use vb.net 2005, here are my 3 favorite sites for vb.net source code.
1) http://www.vb-helper.com/index_vbnet.html
2) http://www.planet-source-code.com/vb...TRUE&lngWId=10
3) http://www.java2s.com/Code/VB/CatalogVB.htm
Free DXF Files - Vectorink.com - myDXF.blogspot.com
  #12   Ban this user!
Old 05-24-2008, 09:09 PM
bsharp's Avatar
bsharp is on a distinguished road
I totally agree. I have used VB6 for a long time and have a real hard time getting used to .NET. I also know C and VB script. If you are starting out without knowing VB6 .NET probably wouldn't be bad.
Lookahead script Rikard L Visual Basic 2 09-11-2007 02:28 PM
Lookahead Script Rikard L General CNC (Mill and Lathe) Control Software (NC) 0 09-10-2007 03:06 PM
Macro/script-can this be done? Splint Rhino 3D 3 02-12-2006 10:50 PM
Script errors anoel Forum Questions or Problems 5 01-13-2005 11:29 AM
Backup Script.. Rekd Mastercam 3 09-11-2003 10:34 AM
