Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 05-15-2007, 10:17 AM
TURNER is on a distinguished road
Question Click On Drawn Entities
Is it possible to draw a series of ellipse on a form/panel from an array holding the ellipse values, and then be able to click on each ellipse to return them values. How would i go about this, & how difficult would it be. I can do the part of drawing ellipse but dont understand how to get a reference to them.
Any help would be great.
Thanks Turner
Old 05-17-2007, 11:41 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
If your working with "VB.net 2005", I would use "System.Xml.Serialization" to keep track of all the different ellipse drawn on the form.
When you draw an ellipse, it's bound to a rectangle.
This link has a good project that will help, it's well commented also. The code is in VB.Net 2003, you can still use it in 2005, when you open the file (with VB.Net 2005) the upgrade wizard will walk you thru it.
Info:
http://www.vb-helper.com/howto_net_d...framework.html
Direct Download:
http://www.vb-helper.com/HowTo/howto..._framework.zip
Newbie, No entities found Shepard Solidworks 13 04-13-2007 01:21 AM
Right-click path options Doug W Hypermill 0 01-05-2007 01:02 PM
click n type dertsap OpenSource Software 0 10-15-2006 04:31 PM
What have you drawn and built entirely on bobcad?? AMCjeepCJ BobCad-Cam 23 01-31-2006 03:09 PM
