Results 1 to 6 of 6
Thread: vb cam
    dim
    dim is offline
    Mar 2005
    greece
    vb cam
    I'm building cad/cam application in vb,it will import dxf drawings and also draw lines-circles-freehand,etc.What maths and algorithms are involved to translate the drawings to motion, step and direction signals?
    thanks
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    The first thing you need to do, is convert the GDI/DXF to g-code.
    Here is a link I posted a while back:
    DIY CNC G-Code Plotter (VB.NET 2005)
    All the source code is VB.Net (2005):
    http://msdn.microsoft.com/vstudio/express/vb/
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    Algorithms to translate dxf to g-code are available in ace.
    http://www.dakeng.com/ace.html
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    dim
    dim is offline
    Mar 2005
    greece
    I would like to bypass the Gcode,what I need is an algorithm to translate the drawings-graphics to direct step/dir sequence pulses.
    Jun 2003
    St. Peters, Mo USA
    Quote Originally Posted by dim View Post
    why? At least with the g-code you have a standard language meant to do positional control that is editable and easy to modify.
    dim
    dim is offline
    Mar 2005
    greece
    well,even if i use G-code,I will still have to interpret the g-code commands to steps/dir,so i was thinking of doing that directly from dxf.how a circle is translated to steps/dir?
  • Posting Permissions
