Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 12-20-2006, 12:32 PM
rweatherly is on a distinguished road
Random Access
I am trying to read the first xxx characters of a .bmp file into an array so I can get the header data. I have done this in VB6, but am having real time with the new lingo.
Can anyone help?
Old 12-20-2006, 01:11 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Can anyone help?
I assume you mean VB.NET?
Old 12-20-2006, 01:19 PM
Switcher's Avatar
Moderator
I'm not really sure what your asking?
This works in VB.NET 2003. So it should work in 2005. (This is some code I wrote a while back, as an example only)
Dim zzz1 As String
Dim zzz2 As String
zzz1 = Format(e.X, "##0.000")
zzz2 = Format(e.Y, "##0.000")
StatusBarPanel1.Text = (" X: " & zzz1 & " " & "Y: " & zzz2 & " " & "Z: 0.100")
Old 12-20-2006, 01:20 PM
Switcher's Avatar
Moderator
Are you looking for a decimal place?
Old 12-20-2006, 02:31 PM
Sorry, I must have been too vague with my problem. What I want to do is open a file for random access, and read from it. In VB6 (from what I remember) you would do this:
dim a as string * 1
open filename$ for random len =1
recloc=100
get 1, recloc, a
The above would get the character at position 100 in the file.
With VB Express (which I think is the same as vb.net) you have a differnet open statement and get statement. I have tried them, but I get a record length error.
I was hoping someone had some sample code that worked.
Old 12-20-2006, 03:10 PM
Switcher's Avatar
Moderator
Public Sub GetPixel_Example(e As PaintEventArgs)
' Create a Bitmap object from an image file.
Dim myBitmap As New Bitmap("Grapes.jpg")
' Get the color of a pixel within myBitmap.
Dim pixelColor As Color = myBitmap.GetPixel(50, 50)
' Fill a rectangle with pixelColor.
Dim pixelBrush As New SolidBrush(pixelColor)
e.Graphics.FillRectangle(pixelBrush, 0, 0, 100, 100)
End Sub
Link:
http://msdn.microsoft.com/library/en...asp?frame=true
Like the RGB color value? The code above gets the "X=50 & Y=50" location of a .jpg (just change to .bmp)
I think that everything in .net has to be declared as a "New Bitmap" no matter what (GDI+ thing, going on)
Old 12-20-2006, 05:33 PM
Thanks for the input, but I should not have mentioned bitmap. My question is how to open and read from a random access file.
Old 12-21-2006, 08:20 AM
NinerSevenTango is on a distinguished road
I personally can't stand dot net.
Sorry, just couldn't resist.
I found AutoIT does what I want without all the random web searching it takes to find out how to do simple things.
I'm sure it's just a mental limitation of mine, but nowhere could I find a concise description of the overall scheme of things. And I found examples of ten lines of code to do simple functions. After spending weeks playing with the language to write a simple routine I chucked the whole thing and went looking for another language.
From now on, I will stay away from any software with the word "enterprise" anywhere on its website.
End of rant, please disregard.
--97T--
Old 12-21-2006, 02:51 PM
97T-
I agree with you. Maybe I am just not the organized type, but it has gotton so "structured" that it makes it difficult to do simple tasks. I realize that it also allows more felxability, but it makes it too difficult to learn and use for simple tasks.
Old 02-05-2007, 10:38 PM
jaredp is on a distinguished road
You may have already figured out your problem, but if it helps I had the same problems with some fills in VB6 and found that it was reading some of the data as on end of file code. I was able to open in binary and loop through till I got the data I needed.
  #11   Ban this user!
Old 02-11-2007, 05:35 AM
rp74 is on a distinguished road
rweatherly- Did you figure out the code for file I/O? I have done this in VS '03, and can pull out some code if you still need it.
  #12   Ban this user!
Old 02-11-2007, 12:34 PM
rp74-
Thanks -- I found several ways to do it. In the end I decided that I would just stick with doing it in Excel.
