Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 12-05-2005, 08:22 AM
GaryM is on a distinguished road
Source code needed!
Does anyone know where I can find the source code that would print out the g-code for an arc? The g-code would look something like this, "N30 G2 X115 Y113.3 I-43 J25.52". Maybe someone know's the math behind this. My little bitty brain just can't quit get a grasp on it. Any help would be very much appreciated.
Gary
Old 12-05-2005, 09:01 AM
ger21's Avatar
If you know the start pint, endpoint, and radius of the arc, you should be able to google to find the math. You'll also need to know if it's CW or CCW.
Old 12-05-2005, 09:35 AM
ger21's Avatar
Actually, if you know the startpoint, endpoint, and radius, the only math you would need is to find the center.
Old 12-05-2005, 09:43 AM
That's what I need. The user would put in the startpoint, endpoint, and radius. Then the algorithym would find the center. Correct?
Gary
Old 12-05-2005, 10:09 AM
Gold Member
JFettig is on a distinguished road
do you have a drawing in say autocad? you can dimention off of the arc.
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 12-05-2005, 10:38 AM
ger21's Avatar
This should get you in the right direction. http://mathforum.org/dr.math/faq/faq...e.segment.html
Old 12-05-2005, 11:59 AM
Jon,
The only cad program I have is Turbocad!
Gerry I will check that out, thank you.
Gary
Old 12-05-2005, 02:57 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Gary,
A while back I posted some Visual Basic source code in the Coding forum. You didn't say what programming language you were looking for, but hopefully you can decipher what you need from it. It includes a function for calculating the arc center from start, end and radius.
Open source geometry stuff
Regards,
Scott
Old 12-05-2005, 08:18 PM
MetLHead,
Thanks, that's what I have been looking for.
Gary
Old 12-05-2005, 10:48 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
http://www.datawise.net/~jorenr/cnc/circleprogram.htm
  #11   Ban this user!
Old 12-06-2005, 07:44 AM
widgitmaster,
Thanks for the link. I am trying to figure out how to use MetlHead's Geometry module to use in a program I am trying to write. I ain't figured it out yet but I'm trying. Must be nice not to be so darn dumb.
Gary
Old 12-06-2005, 07:56 AM
Gold Member
Cool
The best experience is what you learn from major screw ups!
Eric
