Results 1 to 4 of 4
Thread: Which cnc code?
    Jan 2011
    Germany
    Which cnc code?
    Hello
    Does anybody know which code Baldor uses for its mint controller?
    I'm searching for a alternative software to mint nc from Baldor.
    All i know is the controller can't handle g-code. But it can handel active x and visual basic i think.
    Here is an example how the commands look like :
    VectorR
    Prototype:
    VB6 VectorR(nNumberOfAxes As Integer, nAxesArray As Variant, fPosArray As Single)
    VB.NET VectorR(nNumberOfAxes As Short, nAxisArray As Object, fPosArray As Object)
    Delphi VectorR : (nNumberOfAxes: Smallint; nAxesArray: OleVariant; fPosArray: Single)
    C++ void VectorR(short nNumberOfAxes, VARIANT nAxesArray, float fPosArray);
    C# void VectorR(short nNumberOfAxes, object nAxesArray, object fPosArray);
    C void VectorR(__int16 nNumberOfAxes, __int16 *nAxesArray, float *fPosArray);
    Supported by:
    NextMove
    NextMove e100
    MotiFlex e100
    Target supported:
    PC, Embedded
    Description:
    See the Mint keyword VECTORR. If there is insufficient space in the move buffer when the VectorR statement is issued, an erMOVE_BUFFER_FULL error will be returned. This error can be handled using the MoveBufferFull event.
    Examples:
    The following example loads a relative Vector move on axes 0, 1 and 2:
    VB6
    Dim nAxesArray(0 To 2) As Integer
    Dim fPosArray(0 To 2) As Single
    nAxesArray(0) = 0
    nAxesArray(1) = 1
    nAxesArray(2) = 2
    fPosArray(0) = 10#
    fPosArray(1) = 20#
    fPosArray(2) = 30#
    MintController1.VectorR 3, nAxesArray, fPosArray
    MintController1.DoGo 3, nAxesArray
    VB.NET
    Dim axes() As Short = {0, 1, 2}
    Dim positions() As Single = {10.0, 20.0, 30.0}
    AxMintController1.VectorR(axes.Length, axes, positions)
    AxMintController1.DoGo1(axes(0)) 'Could have used AxMintController1.DoGo(axes.Length, axes)
    Delphi
    var
    arrPos: OleVariant;
    arrAxes: OleVariant;
    begin
    arrPos := VarArrayCreate([0,2],varSingle);
    arrAxes := VarArrayCreate([0,2],varSmallint);
    arrPos[0] := 10;
    arrPos[1] := 20;
    arrPos[2] := 30;
    arrAxes[0] := 0;
    arrAxes[1] := 1;
    arrAxes[2] := 2;
    MintController1.VectorR(3,arrAxes,arrPos);
    MintController1.DoGo(3,arrAxes);
    end;
    Visual C++
    const int nSize(3);
    short nAxesArray[nSize] = {0, 1, 2};
    float fPosArray[nSize] = {10.0f, 20.0f, 30.0f};
    COleSafeArray arrAxes, arrPos;
    arrAxes.CreateOneDim(VT_I2,nSize,nAxesArray);
    arrPos.CreateOneDim(VT_R4,nSize,fPosArray);
    MintController1.VectorR(3, arrAxes, arrPos);
    MintController1.DoGo(3, arrAxes);
    C#
    short[] axes = {0, 1, 2};
    float[] positions = {10.0F, 20.0F, 30.0F};
    MintController1.VectorR((short)axes.Length, axes, positions);
    MintController1.DoGo1(axes[0]); // Could have used MintController1.DoGo((short)axes.Length, axes)
    Embedded C
    __int16 nAxesArray[3];
    float fPosArray[3];
    nAxesArray[0] = 0;
    nAxesArray[1] = 1;
    nAxesArray[2] = 2;
    fPosArray[0] = 10.0;
    fPosArray[1] = 20.0;
    fPosArray[2] = 30.0;
    VectorR(3, nAxesArray, fPosArray);
    DoGo(3, nAxesArray);
    hoping for answers
    Mario
    Dec 2006
    New Zealand
    I would also like to know what other cam software I can use with my Baldor Nextmove ESB-2. I have heard that MintNC is not that flash. And it is expensive. I do have Vision Numeric, Type3 cad cam software. Could anyone tell me if I can set my Nextmove controller to interact with Type3?
    I am clearly new at this, and would very much appetite any pointers.
    Regards Steven.
    May 2006
    Quote Originally Posted by stevensea View Post
    Regards Steven.
    Probably none. But ABB will provide you with their Mint Workbench for free. Create yourself a free account on "SupportMe" and download it.
    Login: ABB, a leader in discrete automation solutions
    Dec 2006
    New Zealand
    Didn't think so. I have down loaded workbench, but I thinking that I might be best to cut my losses. ABB doesn't respond to questions regarding the problems I am having with getting a post processes worked out. It is unfortunate that all the advertising for the product does not match reality.
  1. Replies: 4
    Last Post: 03-29-2011, 09:39 AM
  2. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum Siemens Sinumerik CNC controls
    Last Post: 02-20-2011, 11:02 AM
  3. Replies: 8
    Last Post: 12-15-2010, 03:32 PM
  4. Need Help!- G-Code viewing source code
    By Hussam in forum Visual Basic
    Last Post: 03-15-2009, 01:15 PM
  5. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
    By troyswood in forum Ability Systems - LPT Indexer and G-Code
    Last Post: 12-24-2006, 10:21 PM
