Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 06-20-2005, 08:54 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
VB File converter
This is a file converter that I wrote for somebody here on the Zone. I'm posting the Visual Basic source code for it here hoping that someone else might find it useful.
Regards,
Scott
Old 06-20-2005, 09:05 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
I tried a 3D .NC file out of DeskProto....Looks like it just eliminates the N- prefixes (line numbers) from the file...Is that right? What does this converter do exactly?
-Brady
Old 06-20-2005, 09:38 PM
MetLHead's Avatar
Gold Member
Sorry, I should have explained it better. This program doesn't do anything useful for you or I, but was written for somebody who had a specific need for it. I posted it here because it is a good template for other VB programmers to write file converters with.
Scott
Old 06-20-2005, 09:44 PM
Scott
It would be REALLY useful if you could clue us in on it's original purpose...specifically.
-Brady
Old 06-20-2005, 10:16 PM
MetLHead's Avatar
Gold Member
Check out this thread for its original purpose:
Any Way to Improve Processing G Code with Excel?
Basically, it provides a list that you can add files to. When you click 'Convert', it goes through the list and passes each file to the conversion routine which can be modified to do whatever sort of conversion you need. I've used it to convert other file formats to GCode, DXF and others.
Scott
How do i get my autocad file onto mastercam? EdE General CAM Discussion 3 02-23-2011 12:54 AM
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 07:26 PM
Boot disk for EZ-Track DX, batch file? mmm2003 Bridgeport and Hardinge Mills 8 01-31-2007 12:47 PM
3phase servo retrofit whiteriver Servo Motors and Drives 35 02-06-2005 10:27 PM
AutoCad 2000 Missing .dll file E-Stop Autodesk Software (Autocad, Inventor etc) 12 05-30-2003 12:43 PM
