Newbie Programming with Focas library
Results 1 to 4 of 4
Thread: Programming with Focas library
    Jul 2008
    Default Programming with Focas library
    Hey guys, I'm new to the forum and I'm an ME student interning at a manufacturing company. We use mostly 4 axis machines with Fanuc controllers. The project I was just given was to use the Focas1/2 libraries and create a program that will display simple actions (spindle on/off, etc.) of the machines at any time. I have been researching and reading through the Focas documentation but I cannot figure out how to even start this project. I have done a little VBA and C++ and plan on using VB.NET for this project, but I am no programmer. Any help that you guys can provide or even just pointing me towards some tutorials would be amazing.
    Thanks!
    Mar 2005
    France
    First Code in VB6 for Focas; Just in ordre to test the connection between your PC and the NControler
    ' Ethernet connection
    ' allocate library handle 3
    Declare Function cnc_allclibhndl3 Lib "fwlib32.dll" (ByVal sIPaddr As String, ByVal nPort As Integer, ByVal nTimeout As Long, FlibHndl As Integer) As Integer
    Private Sub Form_Load()
    Dim LibHndl As Integer
    Dim Ret As Integer
    Ret = cnc_allclibhndl3("192.0.0.1", "8193", 10, LibHndl)
    End Sub
    Feb 2017
    India
    Default Re: Programming with Focas library
    Can u be little more specific with a sample code ??
    Mar 2008
    Germany
    although we're doing C++ programming the following might help:
    https://www.inventcom.net/support/fa...-states#SOURCE
    You can also take a look at the FOCAS documentation here:
    https://www.inventcom.net/support/fanuc/focas-library
    Martin
