I Like Your program. I would use some of your basics to implement in my sofware for wire EDM. would it be possible to post the code ?
best Regards
Boenke
Hi everyone
I've just started my CNC project for graduation thesis, I'll create a simple CAM software to assist manufacturing on CNC milling machine, it'll be useful when you work with simple cutting contour, it's also free and light. The soft is programmed on VB.net
DXF to G-code is a module of the software. This module reads the data from dxf (Autocad Drawing eXchange File) and convert them to NC code. Up to now - in the first stage of the project, it can read a closed contour created from Lines and Arc.
If you like this, you can download to test it and give me some comments, i'm very glad .
- The module is being improved so there are a lot of bug. I'll try to fix them and add more features such as:
+ Read ellip and spline curve
+ Cut off all the material out side or inside the contour.
+ Add Blank Properties and cutting parameters.
+ Fix unworking function (zoom, pan, preview...)
+ Add cut layers for cutting to a depth...
I'll reupload the soft when finished adding new features. Sorry for my bad English
Thank you all!
This is some screenshot:
Contour with lines
Contour with lines and arc
Test the generated toolpath on CIMCO Edit
YOU CAN DOWNLOAD THE ATTACHED FILES HERE
- Need help with g code for fire control pocket on AR15 lower reciver, have G code.
- Newbie- corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
- Free G-Code Project File Downloads
- Newbie- Takeout Unused G Code commands in Mastercams Generated G Code
- looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
best Regards
Boenke
A newer built with:
- Zig rough milling outside contour
- Blank setup
To use this:
- Step 1: Select dxf file (dxf has lines only, i'm still working with arcs)
- Step 2: Define blank in Blank Setup tab
- Step 3: Input tool diameter
- Step 4: Input stepover (width per cut) (less than tool diameter)
(other features are not done yet, so skip them)
- Step 5: Press generate Button
Demo (generate and verify tool path):
http://www.youtube.com/watch?v=_WJjJkk-cYQ]DIY - 2D CAM SOFTWARE - DXF to Gcode - YouTube
project code?
