Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: More Viper problems
    Dec 2008
    Texas
    More Viper problems
    Having trouble with two Viper 100 boards bought last March.
    One blinks red rapidly as soon as I turn it on, it got increasingly worse over a period of about 4 months on tripping out. As long as the machine was running, it would work fine. Spent many hours retuning, and checking electronics. If that axis sat still for more than 3 minutes, the board would fault out. I took this one out and moved a spare to that axis, a viper 200, am still waiting for a programmable fix for the board so the axis do not jump, without going through extra steps.
    I now have another board that is doing the same as the previous, they are the same age.
    Can you tell me what the problem is? Or how I can fix this without throwing them in the trash?
    It seems to be saying that there is over amperage, but when I check the amps running, very seldom over 4 amps of current. I have checked the tuning repeatedly and cannot see a problem.
    Jul 2006
    Where are you, Kilrabit? I'm in Dublin and about to start a 4 axis retrofit with the viper 200's. What breakout board are you using, in any. What controller?
    have fun
    i_r_machinist
    Dec 2008
    Texas
    I am in Texas.
    I use a c-10 BOB from cnc4pc.
    I use Mach3 as a controler
    Feb 2007
    canada
    If you want to return them, i will check and fix them for you.
    You just pay shipping.
    What size motors ? what voltage are you running ?
    Larry K
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Jul 2006
    Kilrabbit:
    Where in Texas?
    I'm in Dublin, Texas. 70 miles SW of the DFW metroplex.
    i_r_
    Dec 2008
    Texas
    Larkin,
    I am running 1200 oz servos, at 72 volts.
    If you could tell me what you think is the problem, I will fix them here. It will take about 10 days round trip to Canada and back. Also do you have the fix for the field programming in the field on my other boards? The trim and amp adjustment work fine , when you turn them down, the yellow and red lights come on as they are supposed to. The red just continues to flash rapidly, if I move it to another axis it does the same.
    Dec 2008
    Texas
    i r machinist,
    I am about 120 miles west of San Antonio tx. Northwest of Uvalde about 30 miles. Out in the middle of nowhere, which sure is nice.
    Jul 2006
    Camp Wood area? Did some hunting there. I'm from Ozona and McCamey, which is just a little closer to nowhere (Sanderson) than where you are. I've still got family in Ozona, but spend my vacations at a place we have outside of San Angelo. What are you wiring up?
    i_r_machinist
    Feb 2007
    canada
    Tell me all your drive settings.Use ? and 1 and 2
    What version is the firmware , use the v command.
    Do the drives hold (lock) in both directions if you turn the shaft.
    I wish i lived in Texas... you should come up here to canada and i'll show you real cold and wilderness.
    Dec 2008
    Texas
    Larkin,
    I did not check to see if it was still holding when it trips out, I will be back up there Saturday, and let you know. Also the version number, I think it was 2.6 but will double check. I did notice when I used the "z" command it did not set to factory defaults. I will try using another bank when I get back.
    Dec 2008
    Texas
    i r machinist,
    I am 28 NW miles from Uvalde, 26 miles SW from Camp Wood, and 25 miles E from Brackettville, on the West Nueces river. That will put you in the general area.
    This set of boards are on a 10' X 6.5' Gantry Router
    Dec 2008
    Texas
    Larkin,
    The firmware is 2.6h, and when faulted out no power to the servo, free wheeling
  • Page 1 of 2 12 LastLast
    1. Need Help!- Viper 200 warning led, what does it mean?
      By freak_brain in forum Viper Servo drives
      Last Post: 03-28-2009, 09:43 PM
    2. Need Help!- new for: viper v-500/mitsubishi VLC
      By fenix728 in forum General Metalwork Discussion
      Last Post: 11-26-2008, 02:48 PM
    3. viper & boxford
      By bbrreid in forum Viper Servo drives
      Last Post: 02-16-2008, 04:19 PM
    4. Viper lathes
      By Rune in forum General Metal Working Machines
      Last Post: 08-27-2007, 03:45 PM
