I'm getting acclimated with hyper-terminal and the campbell board/Mach3 settings and have the low voltage side of the drives running temporarily from my laptop to test the limit switches etc. Anyhow, starting Mach3 and jogging (with no HV to the drives), On the Z drive only, after jog the axes up, or hit the estop the red warning light starts blinking about twice a second . Onlt the Z axes does it though and switching it to one of the other axes doesn't change anything. Jogging it down seems OK. Programming is the same for all three drives and the setting is the same from what I can tell in Mach3. Makes me think it is something with the drive? Any suggestions? How does one tell wether this is a slow-medium- or fast blink? Thanks much all. Wayne
__________________ YCM-40 converted from anilam to Mach3 and lovin it. Last edited by cwaugs; 09-10-2009 at 11:05 PM. Reason: more accurate info |
| Sounds like the Range setting is doing its job. As you are hitting the end of travel, the encoder error is increasing. Once it exceeds the r setting, it will flash an error. It also could be the current warning setting (yellow Led with trimpot adjustment). You have to get use to knowing the flashing speed by experimenting. I am adding a read command that displays the error in my next s/w version. Are you able to jog it both directions ok when not near a limit ?
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
| I should have field upgradeable firmware in a few months, but for now they have to be flashed on my bench. Larry
| cause for warning light trip | gtool | Viper Servo drives | 3 | 08-26-2009 06:29 AM |
| Newbie- ATC Alarm Light, And Dry Run Light on after PC1 card was removed | Bones75 | Fanuc | 3 | 06-18-2009 04:13 PM |
| a ring of 200 Led Lights to light up? light source render? | Rich05 | Solidworks | 6 | 10-25-2008 07:16 PM |
| Problem- Maztrol M32 - No monitor display No drive light | nbodie | Mazak, Mitsubishi, Mazatrol | 3 | 09-17-2008 03:26 PM |
| Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal | SCG11762 | General Metal Working Machines | 2 | 08-27-2007 09:08 AM |
