Any clues as to a starting point on parameters for these dudes? MT30M4-59 motors running 140 volts. I have hyper terminal talking to the drives but at this early point am clueless as to the majority of the parameters and would greatly appreciate the shortcut. I am using 1000 line encoders so I understand that the encoder trip limit will be t4000 but the rest of the parameters are as overwhelming as the first microprocessor I programmed. Anyhow, any help would be greatly appreciated, but I also understand that the journey is important as to understanding the way it works.
__________________ YCM-40 converted from anilam to Mach3 and lovin it. |
| For tuning, there are just 4 parameters you need to adjust The P, I D and L (Read the (latest) manual and see where it tells about tuning the motor. ) With no bank jumpers the motor should hold. Is it holding ? Start with p200 d400 i4 The L parameter (loop time) needs to be set early in tuning because it matches the motors mass. the range for L for your motor would be 3-7. Set this for the deadest responce when you disturb the motor. The other parameters (range, trip, feedforward) can be set after you have the motor stable. Larry K
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
| Thanks much Larry I'm a ways from actually putting the 140V to the drives yet as I am machining the remaining two encoder mounts and setting those up but I had the drive and power plate in the house on the kitchen table and was getting used to the programming sequence. Again Thank you for the help Sir! Wayne
| AC servo Viper drive ... soon | Larken | Viper Servo drives | 7 | 01-22-2012 04:21 PM |
| Q: Motor tuning. Servo/Encoders | Deviant | Mach Mill | 5 | 01-10-2008 12:19 PM |
| G320 servo motor tuning | robhrzic | Gecko Drives | 12 | 11-01-2007 02:35 AM |
| Viper servo drive overview | Larken | Viper Servo drives | 39 | 06-30-2007 02:36 PM |
| Can Viper 200 drive a Fanuc DC Servo Motor? | maquiza | Viper Servo drives | 10 | 06-07-2007 10:56 PM |
