Page 6 of 7 FirstFirst ... 34567 LastLast
Results 61 to 72 of 82
Thread: supermax YCM-40 to Mach3
  1. #61
    Nov 2005
    I can have only the Campbell board powered up and reset the button and as soon as I start the VFD, it triggers an E-stop. Tried moving the BOB away from the VFD but still happens. Any Ideas?
    YCM-40 converted from anilam to Mach3 and lovin it.
  2. #62
    Feb 2007
    canada
    You can put a .047 uF cap across each limit input right at the BOB.
    If the input is just a non filtered TTL input , it will be sensitive to noise coming in on limit switch wires.
    LK
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  3. #63
    Nov 2005
    LK, You hit the nail on the head. after checking voltages and doing a bunch of re-wiring to re-confirm correct 220v 110v and stray ground loop voltages I finally found about 30 volts of induced current in the wiring to the limit terminal E-stop switch that turns the contactor on for the VFD, and also triggers an E-stop in Mach3 through the same shielded cable going into the aux limit input on the BOB. Going to run a separate cable for the 110v and the limit input and install the .047uf caps as insurance. Also in checking all of this, I noticed that the BOB Led's at the step and direction outputs would actually glow when I turned the output of the VFD on (actually running the spindle and doing nothing else) so I'm going to move the BOB away from that "RFD sprayer" Thanks again very much for pointing me in the right direction. Wayne
  4. #64
    Nov 2005
    After running a relay for the contactor instead of running the 110v up to the ESD switch no more e-stops! Now on to figuring out how to control the VFD with the Campbell BOB plus. Wayne
  • #65
    Jun 2012
    Usa
    Hello there I want to convert a super max ycm-40 to Mach3 can you helpme please I want to use the original servo motors a all ready have the encoders from USdigital 1000 CPR , 5v
    Miguel
  • #66
    Jun 2012
    Usa
    Can some one tell me the experiences in covert the YCM-40 to Mach3 ? What is the best breakout board , the best servo drive ??? Can I use my original transformers ??? Can I skep to buy the hitachi x200 inverter ???
    Thanks to every body
  • #67
    Jun 2012
    Usa
    Thumbs up Supermax ycm-40
    Quote Originally Posted by Miguel-2012 View Post
    Miguel
    Super max ycm-40 to mach3 convert
  • #68
    Mar 2005
    I would go with the Viper Drives from Larry at Larken.
  • #69
    Nov 2005
    And the Campbell board the original transformer and servo motors as well as the original 12v transformer. Can pretty much everything else except wiring and read read read. I tried to document all of my conversion and will help as much as I can but will probably not answer information that is already here. The best thing to do is pick the drives and BOB then find someone on here with the same setup and read all of their posts and take notes and look at pics. HTH
  • #70
    Silver Member diyengineer's Avatar
    Feb 2010
    USA-WA STATE
    Quote Originally Posted by CATCH22 View Post
    I second the VIPER drivers. I have them and use them. Work wonders.
    Also, cnc4pc.com Arturo is REALLY helpful.
  • #71
    Jan 2006
    WV
    update on your machine
    how about an update on your machine how it has been performing what you have been making pictures I am getting started on the Big bridgeport finally
    archie =) =) =)
  • #72
    Nov 2005
    I will try to get some pics but haven't had a lot of time to work with it although what i have done with it has been faultless. YouTube ycm40 Mach 3 and there is video of the last I cut I believe. I will upload the cutting of the flanges I made for my ls1 engine tomorrow if they're not there already.
  • Page 6 of 7 FirstFirst ... 34567 LastLast
    1. Yci Supermax
      By krustykrab in forum Hard and High Speed Machining
      Last Post: 10-17-2011, 09:56 PM
    2. Build Thread- CNC Update Log - SuperMax YCM-40 (Anilam to Mach3)
      By radioactive in forum Vertical Mill, Lathe Project Log
      Last Post: 03-15-2011, 02:51 PM
    3. Need Supermax post
      By Exodus8931 in forum EdgeCam
      Last Post: 10-30-2009, 06:30 PM
    4. SuperMax ycm 40
      By Tymco in forum Knee Vertical Mills
      Last Post: 07-23-2007, 10:46 PM
    5. SuperMax V105 Value
      By coalstove in forum General Metal Working Machines
      Last Post: 10-12-2006, 08:18 AM
