Results 1 to 4 of 4
Thread: Help me
    Jun 2009
    Colombia
    Help me
    hello
    How i to connect the viper servo driver with the Mach3 software?
    Aug 2007
    uk
    Quote Originally Posted by tacoll View Post
    hello
    Hi Tacoll,
    You connect the drive in the same was as a steper motor drive...use step and direction signals from Mach3.
    Thers is lots on info here in the Mach3 section, also have a look here:- http://www.machsupport.com/forum/index.php
    Lots of info
    ATB
    Derek
    Feb 2007
    canada
    You need to get a Breakout board (pc4cnc.com) . They have a bunch to choose from depending on that you want to do.
    Like DerekBPcnc says, you need to go to the Mach3 forum and read on what others have done and what works best.
    Also you need a power supply that matches the servo motors and the speed you require.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Jun 2009
    China
    sure please just use the same way with stepper motors, I just have one time expeirionse.
    maybe need change some pin numbers.
    Best regards,
