Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Viper Servo drives
Old 06-22-2009, 08:48 AM
Danno is on a distinguished road
Weird thing happened with my Viper 200
Larry;
Something weird that has never happened before has me concerned !!
I was changing the tool in the spindle, and for no apparent reason, the Y axis decided to all of a sudden put full power to the servo and rammed the table against my limit.
Just before this happened, I had tripped the drive by bumping the Y-axis a little too fast with the keyboard ( I should know better), but this has happened before and I just reset the drive by unplugging the power to it.
I'm concerned as to why this would have happened. Luckly nothing crashed !!
Dan
Old 06-27-2009, 07:33 PM
Larken is on a distinguished road
Dan
I think you have a bad connection to the encoder, for a drive to run away.
You might want to check the cable connections to the encoder, and make sure the cable isn't pinched somethere in the machine.
Larry
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 07-14-2009, 04:55 PM
gPiplay is on a distinguished road
if the encoder for the DC servo is bad, it is possible for the motor to running
out until hit the mechanical limit, be careful!
For the AC servo, like the ac servo using absolute encoder from DMM Tech,
if the encoder connection is bad, the rotor orientation of brushless motor
will be wrong, then the motor will sticked where it is, no running out absolutely.
Old 07-14-2009, 05:12 PM
Al_The_Man's Avatar
It does not matter what kind of servo or type of encoder feedback, it is up to the controller to detect that a position error exists and shut the drive off.
Whether the servo loop is closed back to the CNC control or an intelligent drive.
All the systems I use work this way.
Even in the event an encoder signal is missing.
Old 07-14-2009, 05:26 PM
All my Viper drives have this feature now (for about 6 months) that if the encoder is dead, the drive will shut down.
Dan's Viper is an older firmware version (but can be updated).
Yes an AC servo, Brushless and stepper can't run away if the drive fails, But
these mills are retrofits using the existing large DC servo's so replaceing the motor is usually out of the question.
Larry K
Old 01-21-2010, 03:47 AM
tjs88yj is on a distinguished road
Larry K
I also have 3 of the older Viper 200 firmware version. What is involved in updating them?
Tom
New Machine Build- What just happened??? mulligan CNC Plasma and Waterjet Machines 10 07-02-2008 03:58 AM
When has this ever happened to you? thetrillionaire Haas Mills 2 03-01-2008 11:35 PM
What happened here? turmite BobCad-Cam 8 02-05-2004 09:02 PM
A funny thing happened on the way to the forum BIG AL General Metal Working Machines 2 01-29-2004 03:15 AM
