Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Viper Servo drives
Old 05-19-2009, 09:11 PM
MSGMachine is on a distinguished road
Milltronics Partner
I have a Milltronics Partner knee mill that I am getting ready to retro-fit with mach 3.
I now have only 2 axis, but after I get the x and y axis going I plan to add a z axis.
I am looking at using the viper drive, and I wanted to know if you could recommend a setup for me.
Just to look at the specs it looks like the 100v drive would work, but I am concerned about BEMF (back electromotive force).
My motor specs are attached. (MT30F4-25)
Old 05-20-2009, 10:25 AM
Larken is on a distinguished road
The 100 volt drive (Viper 100) has the same power mosfets as the Viper 200 which are rated at 250 volts @ 56 amps, so the back emf isn't a problem. The difference between the 2 drives is the voltage regulator range (25-100V or 50-170V) and the main capacitor (680uF 100V or 390uF 200V)
Also i can build the V100 with smaller connectors (10 amp vs 20amp) if requested, for space and cost savings.
What PS voltage do you plan on running ?
Larry K
http://www.viperservo.com/V200.htm
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 05-20-2009, 05:39 PM
Talking PS Voltage
I plan on running around 90 volts out of the power supply at 20 to 30 amp.
the amp. rating is kind of a gray area for me.
The motors are driving a reduction pulley at 2 to 1, to a .200 lead ballscrew.
If I have calculated right the spike in amp. shouldn't be over 14 or 15 amps per motor.
Does this sound right to you?
And this time I did this time I did attach my motor specs.
Motor #: MT30F4-25
Old 06-01-2009, 09:52 PM
I just built a chassis with a 1000 watt 90Vdc PS and 3 Viper 200's mounted on their edge. I will post a picture.
I get the toroids made here in Canada by SumR in Toronto. Costs more than china, but exellent service and quality. I get a 12V 1 amp secondary winding to power the control board in the same transformer.
Those motors should be no problem.
No one ever puts a PS capable of driving all 3 motors continuosly at peak current, unless you know the machine will be at 100% load all the time.
20-30 amps should be fine.
Old 06-02-2009, 09:22 PM
Question To make sure i'm correct
So do you think that I could get away with 3 Viper 100's or do you see a need for me to have the 200's?
I thought there might be a reason you used the 200's over the 100's in the 90 volt system you discribed.
Need Help!- milltronics Partner 1 Bada Bing Milltronics 7 01-26-2009 12:54 AM
Milltronics Partner I - For Sale Leehound Milltronics 3 03-24-2008 01:27 PM
How to use a VFD to convert Milltronics Partner iv to 1ph ozturbo Phase Converters and VFD 0 03-22-2008 05:21 PM
Milltronics Partner ? Centurion V Servo Questions sbalder Milltronics 8 02-07-2008 10:35 AM
Milltronics Partner IV Ben Colby Milltronics 6 03-27-2006 05:53 PM
