Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Viper Servo drives
Old 04-30-2009, 11:47 PM
luis_gts is on a distinguished road
E-stop and Fault indicator HELP
Hello
i was reading the viper manual, and i found this :
A small 12 volt reed relay can be driven by the stop output to allow you to use a N/C
Estop connection. Put a reverse diode across the relay coil to suppress kick back.
Can somebody pass me a detail diagram of how to do this???
Old 05-04-2009, 04:20 AM
jdguitars is on a distinguished road
I had the same question and ran across an answer related to something else. If you go to this link http://www.kpsec.freeuk.com/trancirc.htm and scroll down to where it says using a transistor as a switch, it also talks about using a relay and placing a diode across the coil to avoid the high voltage spike when the power turns off to the relay coil. Hope this helps.
JD
New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop GreenLead LinuxCNC (formerly EMC2) 12 08-03-2010 01:05 PM
Best Coaxial indicator to buy? aaron p CNCzone Club House 3 03-05-2009 02:30 AM
Servo fault at pgm stop pommac Fanuc 2 05-25-2007 07:58 AM
