Hi Guys, I'm trying to figure out the correct transformer and CAP I need to make a power supply for my servos and drives. I'm going to have 4 Viper 200 servo drives and I need 120-130 Volts and 15 amps RMS to power my servos. I'm a bit confused as to what VA number I need for the transformer. I do have a 500 VA 115V power supply that came out of the machine but my guess is that this is not big enough?....It has H1 H2 H3 H4 with 0v/208v/230v/460v respectively on the input side and on the secondary side has X1/X2/XF(filter) . Any help would be appreciated |
| Plugging the numbers into my calc sheet it looks like a 1.6Kva transformer for 60% duty cycle, 7300uf Capacitor for 5% ripple at 120vdc at 15 amps. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I would get a 160~180vdc min, or go with a 200v for enough margin. Al.
| Thanks for your excellent feedback again Al. Do you or anyone else know where I can find a 1.6-1.7 Kva transformer? I'm begining to think I might need break it up into seperate power supply's for each drive....yikes! |
| Are you using the original motors? If so, if the original supply is still there, I would tend to use it if possible, presumably it did the job so far for the same load & motors. Al.
| Hi Al, It's a little complicated (for me) because I'm terrible at math. The original power supplies are broken up into seperate smaller ones to power the amplifiers and drives seperately. 4 of the transformers all have different VA ratings too. I might be able to salvage a few of the older transformers once I figure out exactly what I need. For now I decided that I'm going to to break it down into seperate power supplies for each drive since finding a 1.7 KVA has been immposible. Al, would you mind helping me out again with another calculation? If I made a seperate PS for each drive/servo what size transformer and CAP would I need for each at: 120 Volts and 14 amps ? Thanks in advance for your help. -Kirk |
| Al.
| I'm not exactly sure if some of them are or not. What would the VA # on a transformer be for 120VDC/14 amps? It's strange because there are'nt three of the same transformer for XYZ. There are about 7 transformers and they are mostly different sizes. Some of the transformers are rusty and the caps are starting to bulge out so I thought I would start over and replace them. I'm targeting 120VDC and 14 amps based on the servo spec. |
#10
| What you need to supply is the motor ratings. Then some idea of what you need could be calculated. Al.
#12
| Those are fairly large motors. For 120vdc and 5% ripple @ 14amps my sizing program gives the following. 6800µfd 1.4kva @ 60% duty factor. 86vac secondary. Al.
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 06:13 AM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 08:03 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 03:56 PM |
| PC power supply, ATX | freak_brain | General Electronics Discussion | 6 | 02-25-2005 04:43 PM |
| power supply | asd | General Electronics Discussion | 2 | 07-10-2004 05:53 PM |
