I drove a few hundred miles the other day to help a customer that was putting Viper 200's on a Hurco mill. He was having some problems and i wanted to test the drives myself because it was a good opportunity to test the drives on a big mill . He is running 160 volts and had blown a few of my older gen drives, so i came up with my latest with Short curcuit protection and that did the trick. There was a few other problems, the Y axis encoder wasn't working and i removed some extra wire that was running to breakers before the drives. We slammed it hard a few times (accidently) and once i purposely fed it into the end and keep pushing until it blew a fuse. But it didn't blow the drive ![]() I will post some pictures. Thanks to Dan at Pimpbike .com for his patience. Last edited by Larken; 02-16-2008 at 05:03 PM. |
![]() Here is the beast. which is now tamed and running Mach 3 and Viper drives ![]() Here is the controller. He's running a breakout board by PC4CNC (i think) . The power supply is behind this cabinet and has a huge toroidal transformer. It runs at 160 Vdc with a fan blowing on the drives. ![]() Here is the electrocraft servo ![]() Dan (the owner) makes fiberglass molds and vacu-forms. He made the console for his Mach3 setup. Wow, really nice work. |
Hello I recently purchased a Hurco MB1 in an auction, and I know it will need retrofitting. Hurco replied that they have no retrofit for thi product. Can you please advise what to use. I want to use Mach 3 Thank you in advance innovativeiron |
| The Viper 200's will drive it. You will need a 140 volts PS, breakout board and a lot of time. Its high voltage, so it should be done by someone with electronic experience.
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
| Hurco Mb1/Mach3 retrofit | SilvioB | HURCO | 9 | 02-17-2010 11:41 AM |
| Hurco Tm-5 retrofit?? | pimpbike | HURCO | 14 | 04-11-2009 07:01 PM |
| VM1 Graphite Hurco Mill | loginname99 | HURCO | 1 | 08-21-2007 10:08 AM |
| Hurco Kmb-1m retrofit with Ajax system | cybeeria | AjaxCNC Control Products | 6 | 08-04-2006 12:13 AM |
| Retrofit on Hurco | Steve@Reliance | HURCO | 4 | 02-07-2006 01:28 PM |
