not sure about shipping , same as UK . maybe ask at your postoffice. whats the total payable and the best way to get the payment to you brian.reid@fsmail.net Brian
__________________ BR Last edited by bbrreid; 11-17-2007 at 03:46 AM. Reason: forgot email address |
Larry, drives arrived now the tricky part , fitting them.I have a choice of 4 machines to fit them to. one has glass scales instead of encoders will the boards work with glass scales. thanks
__________________ BR |
| You can use a glass scale if it has a A and B channel quadrature output. BTW, since i sent you those drives, i've added some components for hardware current limiting. It makes the drive really tough. I will send you the parts and instructions to add them. Do you have a fine point soldering iron ? Larry K |
#10
| Its hard to get big caps rated at 200V, so if you can get 8000-10000 uF then that should be ok. You can use 2 4800 uf's in parallel. The trick is to keep the wires less that 8-10" between the main cap and the drives. This means NO running to a remote fuse or breaker after the main cap. |
| 40 Amp 250 volt Viper coming soon | Larken | Viper Servo drives | 28 | 11-15-2011 12:58 AM |
| Viper 200 Initial Impressions and Experiences | sbalder | Viper Servo drives | 32 | 02-16-2009 12:19 PM |
| Viper lathes | Rune | General Metal Working Machines | 4 | 08-27-2007 03:45 PM |
| Mach2/3 servo with Viper drive | Larken | Viper Servo drives | 4 | 03-31-2007 12:32 AM |
| Need a Viper emblem Drawing or Model | CDignition | Solidworks | 4 | 10-01-2003 10:51 AM |
