Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Viper Servo drives
Old 06-30-2007, 08:42 PM
rolveram is on a distinguished road
Question problem with servo vipers
I recently acquire three viper 200 servo motor drive for a matsuura mill retrofit. In first instance we had no problems with the config of all of them separately, but when we try to run them in the machine some strange happened when we turned on that one of them begin to oscillate violently, and when we check the parameters had different value than we put in.
I think that probably may be noise but I don´t know how can I know exactly what is happening. Can someboy give me some tips to check whats going on?
rolveram
Old 07-02-2007, 06:45 PM
Larken is on a distinguished road
Get each axis working and tuned separatly before trying to run all three. Disconnect the main power to the other 2 drives while tuning each one.
What is the powersupply voltage for the control side ? Is it stable ?
Have you changed the L (loop) parameter first to its best value, while PID are set low ? ( as described in the manual)
What PID settings are you running. 400, 0 and 800 are good for testing. Change the L setting 2-8 until the motor seems most stable.
There is a small bug in the display routing that sometimes prints wrong characters when you use the ? (show settings) command. So do it a few times to get a consistant result when you use ?
Larry K
Help! Servo controller problem on Leadwell VMC SRT Mike General Metal Working Machines 3 12-14-2007 08:16 AM
Servo motor problem after teardown? altered Servo Motors and Drives 18 04-22-2007 03:48 PM
Problem with servo controller (G320) faststeve Gecko Drives 19 04-03-2007 09:18 PM
Servo system tuning problem?? REVCAM_Bob CNCzone Club House 2 12-17-2006 08:20 AM
Fanuc servo / encoder problem Andy Fritz Servo Motors and Drives 11 10-15-2006 01:44 AM
