Hi All,
I want to try Viper250 with Super Line SDN-MFZ-VF spindle, I will install a 1000 line encoder for it.
Any chance of success?
Wee K.
These motor are/were typically used with large 3 phase SCR drives, you can roughly calculate the very high initial current, that can occur if steps are not taken to accelerate this very slowly on a lower current-capable drive.
If the armature has not had the opportunity to develop back EMF and if the armature resistance is typically around .15 ohms and your drive happens to reach a full 120vdc output, then the Potential motor current could initially be ~ 800amps.
Hopefully this is a PM motor and not a wound field?
Hi All,
Wee K.
What voltage will the power supply be ?
That motor has a field winding. You would have to get a separate circuit for that.
LK
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Voltage for rotor is 210 VDC and need some margin for handling regenerative energy during deceleration.
I will provide field winding power separately, probably through adjustable current regulator.
Wee K.
Due to interest in large drives lately, I will be making the Viper 400. It will be a a full 350 volts and 40 amps. I'm using a DSPIC on a daugter board above the main power board.
This drive will also be available as a AC 3phase servo eventually as well. It will be priced under $300.
Hopefully i will have it available by early 2012
Larry
Any update on the Viper 400?
