| Jason, what do you plan on doing with those motors?
| I am planning to use them on my belt driven 5x10 router. They may be overkill but the gantry seems to be turning out heavier than I expected. The gantry will be possibly constructed from 150mm x 80mm hollow section with a 6mm sidewall (I think), so its really heavy. I am estimating gantry weight to be at least 200 lbs with all accessories. So driving the long axis from both sides I am assuming that quick changes in direction will require some really beefy motors. The long belts will be 25-32mm wide belts with a 6.25 to 1 reduction. Jason |
| Just a guess, but I think that's far more power than you need. 200lbs isn't that much weight.
| About what size would you think is suitable. I also noticed that all of these new RS motors from homeshopcnc need lots of amps, even the weaker ones. The 1840 oz/inch and the 1290 oz/inch models also need 8 amps in parallel mode. http://www.homeshopcnc.com/page6.html Jason |
| Higher current motors are better for higher speeds. I'd rather not give a suggestion, as it would just be a guess. How fast are you looking to go? Do they have any torque curves available for those motors? From what I've read, large motors typically don't run as smoothly as smaller motors. Fwiw, I've sen a few machines here using 400 oz motors with 2 turns/inch screws able to rapid at 300-400ipm, with gantrys that probably weight over 100 lbs, maybe more. Check out routers by Hack (Data-Cut plans) and Inventit.
#10
| Pls check here for stepper motor info http://www.kelinginc.net/SMotorstock.html |
#11
| For steppers, why not look at keling? you can get the motor AND the drive from the same place, and they can help match the package for you. I built many cnc machines, and when using components that come from differn't places, if something don't work right, the drive manufacture simply point their finger at the stepper/servo motor manufacture, and the stepper/servo motor company points their finger at the drive manufacture. No one takes the blame. If you get them from the same place, you have that potential problem solved. I believe you can get the power supply from Keling also, now you have that matched with everything also. I installed some Kelings and liked them. Good Luck, Buck |
#12
Above 8 amps keling does not have a drive to push the motors, the largest I saw was 7.8 amps. Jason |
| drivers for stepper motor? | visky | Stepper Motors and Drives | 0 | 01-22-2007 03:27 PM |
| stepper motor drivers | nurseling | General Electronics Discussion | 5 | 01-16-2007 05:43 PM |
| Stepper motor drivers ? | Clyde Crashkop | Stepper Motors and Drives | 7 | 11-26-2006 06:39 PM |
| stepper drivers | Nilesh | General Electronics Discussion | 3 | 06-22-2004 09:05 PM |
| stepper drivers | DDM | DIY-CNC Router Table Machines | 1 | 01-19-2004 01:58 AM |
