Welcome to the new forum for the Viper servo drive. Its available in two models Viper 100 80 volt @ 20 amps and Viper 200 180 volt @20 amps These drives are loaded with the features you need to control cnc routers, mills and lathes etc. For more info on Larken's servo drives check them out on the website http://www.larkencnc.com/viper/index.shtml Larry kenny |
| Hi Larry, Good looking product. I would like to offer a little bit of gentle advice! Your website is somewhat difficult to navigate. If all pages were vertical it would be much faster to read everything. I don't know if it's just my pc, but I had to navigate both vertical and full page horisontal to get all the info. I also noticed you posted about customers with Mach giving feedback. Would it be possible to get a little more detail.....since I use Mach? Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| Thanks, i will check that . It should be no more than 800 pixels wide. The customer manufactures cnc routers and Lasers. They commented that they could run faster and smoother with the viper than the other 2 popular servo drives. One reason is because on the other drives they overshoot when the Derivative is increased to settle the motor. The viper's enhanced PID control settles without overshooting. This makes it follow Mach2's contouring more accuratly and you can run faster. |
| Thanks for the info. I got your pm as well. I currently am using steppers but my next machine will likely have servos on it. I hear so many good things about speed,smoothness etc. Mike
| Very interesting product. I'm fixing a broken Bridgeport clone retrofit that has a 115VDC power supply. The old drives are shot, so I was thinking of trashing everything and setting up a 80V Gecko-based system. Your 200V viper would simplify my job a lot, although the parts cost would actually be more expensive ($239 x 3 = $717 vs $114 x 3 + $150 for PS = $492). I like that it can use single or differential encoders, and am intrigued by the storage of multiple motor configurations. I've dreamt of building one controller box for a mill, lathe, & router (since in a garage setup like mine, you only have one machine active at a time) with a selectable switch on the front for the appropriate machine. The multiple motor config makes this possible (although still not simple - lots of relays required). Have you ever used these drives in conjuction with a Geckodrive G100 motion controller? |
| The KL34-150-90 Servo Motor is working good with Viper servo drive. If you are looking for the Servo Motor, pls check www. http://www.kelinginc.net/ServoMotor.html |
#11
The encoder power has a separate 7805 regulator, so it can supply as high as necessary. |
| Viper lathes | Rune | General Metal Working Machines | 4 | 08-27-2007 03:45 PM |
| Servo drive / Servo Amplifier | Ken_Shea | Servo Motors and Drives | 9 | 07-10-2007 06:12 PM |
| Some one Gimme an Overview | big_mak | Rhino 3D | 1 | 08-01-2006 05:47 AM |
| Simple Overview | Cold Fusion | OneCNC | 13 | 01-08-2005 11:48 AM |
| Need a Viper emblem Drawing or Model | CDignition | Solidworks | 4 | 10-01-2003 10:51 AM |
