Results 1 to 3 of 3
Thread: crashed machine, viper not coming up
    Jul 2006
    4 axis milling machine has been running great. Very satisfied. Bob Cambell board and viper 200 drives, driven by mach3.
    I messed up and ran past a limit switch and the axis hit the end of travel. I manually moved the axis back and tried to reset the drive by disconnecting the viper 200, but the little red light starts flashing immediately, and the green axis indicator light on the bob is out. This was late last night and didn't have time to dig the book out and start troubleshooting.
    Did I fry the board?
    thanks
    i_r_machinist
    Jul 2006
    Thanks for dumbass proofing your drives Larry.
    Replaced 15 amp fuse and I'm back in the saddle.
    have fun
    i_r_
    Feb 2007
    canada
    Great, that fuse is there to save the motor. The fuse should be rated at or just above the continious current of the motor to save the windings incase the machine gets stuck or sits forcing the motor.
    I've talked to many people who run without limit switches and had a machine sit stuck at the end of the travel pushing, and then poof ... there is a bad smell of the motor fried! . 10 seconds at double the current can fry a servo.
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  1. 40 Amp 250 volt Viper coming soon
    By Larken in forum Viper Servo drives
    Last Post: 06-18-2012, 12:50 PM
  2. EC2.3.5 Crashed
    By erlyrisa in forum LinuxCNC (formerly EMC2)
    Last Post: 07-29-2010, 01:50 AM
  3. Need Help!- Viper V-950/OS crashed,lost all parameter
    By jesse297 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-29-2009, 08:57 AM
  4. Need Help!- Crashed Our VF-2 Need help
    By DaOne in forum Haas Mills
    Last Post: 04-20-2009, 03:24 PM
  5. Need Help!- crashed the machine, now spindle makes weird noise!!!!
    By lm6769 in forum CNC Machining Centers
    Last Post: 09-01-2008, 01:23 PM
