Results 1 to 12 of 12
Thread: What US digital encoder for Viper 200?
    Mar 2005
    Question What US digital encoder for Viper 200?
    I am going to order my encoders to go with my Viper 200 servo drives and I was planning on using the E5 US Digital encoder with 1000 cpr has anyone used these or something else that works well with these drives that they could recommend for my setup.It will be going onto a Excello 604 cnc milling machine.
    Thanks Mike
    Feb 2007
    canada
    Yes, the E5 (or E6 for bigger shafts) with the differential option works great.
    I use a lot of these on our own cnc routers.
    For the connector (10pin housing), I use Digikey part# WM8037-ND for the Housing and WM2558-ND for the Pins.
    Use twisted pair (stranded) network cable and the 9pin D connector (I supply)
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    I'll second that. Be SURE and get the differential option. Makes your encoder far more noise immune. i put them on an Excello 602. Almost the same machine.
    Mar 2005
    Ok thanks guys, but what is the differential option,and should I go with more than 1000 cpr or is this the best count to go with?
    Thanks Mike
    Mar 2004
    Dassel,MN,USA
    Quote Originally Posted by CATCH22 View Post
    Thanks Mike
    Differential, in my limited understanding, always powers the square wave pulse to either +5 or -5V. The other option is +5 V and not powered. If you have line noise the unpowered period can stay above the 2.2 volt cutoff and you miss a pulse. This is not uncommon. I put the cheap one on my CHNC lathe. When ever the air turret was indexing, it missed pusles and slowly caused the axis to get off. It made out of tolterance parts then. I had to go back and put differential units on to solve the problem.
    For count you want a very even number when making small moves so you don't call for paet of an encoder count. My 602 had 5 turn per inch ballscrews so i went with 2000 count encoders or 100,000 count per inch.
    Karl
    Gold Member
    Sep 2003
    Differential noise immunity is based on common mode rejection. The reciever can only detect a difference in the SIGNAL and [U]SIGNAL[U]. If the same noise appears on both lines it is rejected. There is no -5v used.
    Darek
    Dec 2003
    Another spin, a differential has 6 conductors rather than 3, there is a complement signal for each A B & I signal.
    See RS422 standard.
    http://www.lammertbies.nl/comm/info/RS-422.html
    Mar 2005
    Ok thanks for all the replys, now will it make any difference if I go with 1000 cpr or 2000 cpr. Will it make my rapids slower?
    Thanks Mike
    Dec 2003
    Quote Originally Posted by Karl_T View Post
    my 602 had 5 turn per inch ballscrews so i went with 2000 count encoders or 100,000 count per inch.
    Karl
    I would interpret that as .000025" resolution for 2000c/turn enc?
    (2000*4)*5 = 40000 pulses/inch. One pulse = .000025"?
    The encoder should always be quoted in the basic quadrature pulse for one signal per rev from the manufacturer, the quadrature pulses are then usually multiplied x4 the basic pulses in the drive or controller.
    Feb 2007
    canada
    Karl
    Thats 10,000 counts per inch.
    (or 40,000 with 4x decoding) but typically you use a 4 x step mulitiplier which brings it back to 10,000 steps /inch
    Mar 2005
    Question
    It looks like I will have to go with the E6 because the E5 only goes to 1250 cpr. So I will be going with part # E6-2000-375-I-D-D-D-B
    There is one more question I have for ordering on the US Digital web site under Configure and Purchase there is the option of No Index or Index (3rd channel) which one of these do I want or does it even matter?
    Thanks Mike
    Mar 2005
    I just talked to Larry at larken and he has cleared the index issue up for me.
    The viper drives work with no index. Thanks again Larry.
    Thanks Mike
    1. Digital Version of Digital Machinist
      By castiron43 in forum Village Press / Digital Machinist
      Last Post: 01-29-2013, 09:41 AM
    2. Problem- Is this encoder bad US Digital Discoloration spots Timing out
      By TitaniumCannons in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-03-2010, 09:35 AM
    3. Help with Gecko320 and US Digital Encoder
      By BWay in forum Gecko Drives
      Last Post: 06-28-2009, 09:06 AM
    4. Replies: 1
      Last Post: 11-30-2007, 08:20 PM
    5. Encoder for digital readout on bender?
      By Pook in forum General Electronics Discussion
      Last Post: 05-15-2007, 06:20 AM
