Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Viper 200 frustration!
    Apr 2009
    England
    I'm trying to get the fault output to work on my Viper 200's.
    I can get the remote flashing LED to work, but nothing from the "stop out" connection. I need this to tell Mach 3 that there is a drive in fault.
    I assume my drives are the latest batch as they're not quite the same as the pics in the manual, there's a jumper block next to the Stop out connector, but no documentation to tell you whether you need to install jumpers? (see attached pics)
    Viper's website has been down for a couple of weeks now & I've had no response to email.
    I've tried to ring, but got the answerphone. I'm in the UK so not sure if the time difference means I'm calling at the wrong time.
    Getting quite frustrated now
    Attached Thumbnails Attached Thumbnails Viper 200 frustration!-20110715_001.jpg   Viper 200 frustration!-20110715_002.jpg
    Feb 2007
    canada
    The output doesn't pull low, eh ? What value of pullup resistor do you have ?
    What voltage do you measure on the output pin ?
    The pin header is just extension of input signals.
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Apr 2009
    England
    Hi Larry,
    I have 5v on the middle pin of the 3, I can't measure anything on the stop out pin & I can't detect any change of state.
    If I connect an LED across the same as the flash output, I don't get anything.
    Resistor is 470Ω
    Feb 2007
    canada
    Quote Originally Posted by Timvmax View Post
    Hi Larry,
    Resistor is 470Ω
    When you say 'can't measure anything', does that mean zero volts ?
    Also when you connect a LED thru a series resistor to the +5Volts, does it glow or not glow ? Be sure the long lead on the LED is on the Pos side.
    Its possible its a firmware problem (since yours were early 2nd gen )
    Larry
    Apr 2009
    England
    I have connected the LED & resistor accross the 5v & the stop out pin and it doesn't glow.
    I am at the point where I can run the machine, but have no way of telling if a drive faults out. I may use the flash output to e-stop Mach 3, at least it's going to limit any damage.
    If it's a firmware problem, is there any way of changing it here, or do you have to do it yourself?
    Apr 2009
    England
    Sorry I forgot to answer about the voltage.
    If I put my meter accross the 5v & stop out pins I get 0.4v. It doesn't change if there is a fault output or not.
    Apr 2009
    England
    Tried to reply to your pm, got this error:
    Larken has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    My reply to your pm therefore is:
    I tried that,
    it's ok
    I tried several times to be sure & it's ok every time.
    I am running with the flash output connected to my breakout board to put Mach 3 in estop.
    Not ideal but at least I can run.
    Apr 2009
    England
    Larry,
    will you please get back to me?
    Feb 2007
    canada
    Do you have the drives running your machine (even though the error line isn't working ) ?
    Apr 2009
    England
    Yes the drives are working, but I have the fault line as an e stop, which means if I go near my current limit I get a 3 flash fault, which estops my machine.
    Apr 2009
    England
    I am also experiencing random e-stops, sometimes when it stops for a tool change. When I check the drives there is no fault showing.
    As this machine has been running well for 2 years on Gecko drives, I can only assume it is the fact that I am using the fault line on the Vipers as an e-stop.
    Is it possible that this line could randomly give an "output"? Normally this would only light an LED, so it wouldn't show up as a problem.
    Feb 2007
    canada
    Hey Tim , I send you 3 replacement drives about a month ago. Did you get them ?
    let me know whats happening.
    Larry
  • Page 1 of 2 12 LastLast
    1. Problem- 3D Frustration
      By Timvmax in forum BobCad-Cam
      Last Post: 08-17-2009, 07:08 AM
    2. Too much frustration. help.
      By Teyber12 in forum Benchtop Machines
      Last Post: 08-14-2009, 09:35 PM
    3. Need Help!- Frustration with Taig Micro Mill
      By vonnieda in forum Benchtop Machines
      Last Post: 07-28-2009, 04:53 PM
    4. frustration....plasma cuts off during cuts any ideas?
      By gpnjuice in forum General Waterjet
      Last Post: 11-18-2007, 07:45 PM
    5. Commercial CNC Frustration
      By mcnotashark in forum Commercial CNC Wood Routers
      Last Post: 11-14-2005, 07:35 PM
