Page 13 of 13 FirstFirst ... 310111213
Results 145 to 147 of 147
Thread: Sharnoa 4 axis retrofit
  1. #145
    Nov 2005
    Hey lr, was wondering if you ever figured out the e-stop when starting the spindle as that is what is happening on my machine right now. I can have only the Campbell board powered up and reset the button and as soon as I start the VFD, it triggers an E-stop.
    YCM-40 converted from anilam to Mach3 and lovin it.
  2. #146
    Jul 2006
    I got tired of messing with it and just wired the vfd to run off of a pot. Works fine, I just edit in a dwell to adjust my spindle speed before cutting. Its been working great. If you figure the problem out, I'd like to know what the fix is.
    Other than that the machine is running fine. I'm pretty impressed with some of the canned cycles in Mach3. Very handy for quick machine path.
    have fun
    i_r_
  3. #147
    Nov 2005
    Found out that the E-stop was inducing 35 volts into the contactor solenoid wires that also run up to the e-stop switch in the same cable AARGH. Then I'll mess around with the Mach3 BOB controlling the VFD. (Probably in another YEAR or so)
  1. Lagun 3-Axis Retrofit
    By millnturn in forum Knee Vertical Mills
    Last Post: 09-24-2010, 02:28 PM
  2. VMC retrofit Z axis assist?
    By wyobmf in forum General Metal Working Machines
    Last Post: 12-30-2008, 11:01 AM
  3. Need Help!- 3 axis mill retrofit
    By beezerlm in forum Mach Mill
    Last Post: 03-20-2008, 10:36 PM
  4. BP S1 Z axis retrofit
    By CNC OT in forum Bridgeport and Hardinge Mills
    Last Post: 09-05-2007, 04:42 PM
  5. x2 retrofit x axis question
    By h_2_o in forum Benchtop Machines
    Last Post: 02-03-2006, 12:15 PM
