Page 11 of 13 FirstFirst ... 8910111213 LastLast
Results 121 to 132 of 147
Thread: Sharnoa 4 axis retrofit
  1. #121
    Jul 2006
    I have a rev5 board. It has a sig and Vgrd terminal. The sig is connected to A1N and the Vgrd is connected to Com.
    If I disconnect one of the wires from the output relay and give mach3 a m03s1000, the board will not fault and I get a voltage of about 3vdc across sig and Vgrd.
    i_r_
    Attached Thumbnails Attached Thumbnails Sharnoa 4 axis retrofit-screenshot.jpg
  2. #122
    Jul 2006
    Got frustrated with the spindle speed issue, so I just wired it up to turn on and am using a pot to manually set the speed. I'll revisit the issue at a latter date. All axis but the rotary table are working, I need to get the power connection for that board,(burned the other one up).
    I'm going to pretty some things up and then post some pictures of it.
    I want to thank you all for dragging my big butt through this whole project!!!!
    i_r_machinist
    aka
    Kerry Bullard, Dublin Texas
  3. #123
    Sep 2006
    Way to go I_R.
    I'll be looking forward to the pics. Can you make a video of it running?
    JAckal
  4. #124
    Jul 2006
    I looked just like that marshmellow guy dancing around in my shop!
    I'll have to take a shorter video today because I can't upload one I have.
    http://bullyztoyz.smugmug.com/Machin...38522141_fi5X2
    I have a picture of it running here.
    haveing fun!
    i_r_
  • #125
    Sep 2006
    Man ,that looks good!!!
    It seems like forever away for me, but I'll get there. I just have to start first.
    JAckal
  • #126
    Jul 2006
    Talking
    Video loaded! Its the next icon over on the smugmug link.
    I wouldn't hesitate to start, as long as Larry,Al,Bob, and Kieth are around!
    I had a little problem with my y encoder this morning. The ground wire had broken off at the bottom of the pin. I'll play with ramping up feeds and rapids soon.
    Mach3 is almost too easy to run.
    Haveing fun
    i_r_machinist
    PS. The way I started was to disconnect power, drink six adult beverages, then rip out the control! With no way back, the only path is forward!
  • #127
    Sep 2006
    Kerry,
    That is great!!!! I'm glad to see it running. It's motivating for me.
    I also have a little cheat help, too. On another thread where I asked about setting up Vipers, a guy named freak_brain < "Allen" started replying. He has the exact machine (almost) that I have. He said that he would give me his Viper setting and Mach 3 settings, too. It might not be EXACT for my machine, but it would be a good starting point for fine tuning.
    Here is the link where Allen comes in.
    Question about setting up viper drives.
    If this works out ok for me, I know where there is a Wells Index cnc with the kwik switch spindle, that needs retro. Last time I asked he wanted a gold mine for it, though.
    Keep posting new stuff.
    JAckal
  • #128
    Jul 2006
    Got my waylube wired up last night. Now I need to get my power drawbar working. I have a Blackand decker model 2214 120v ac/dc impact wrench that has 4 wires coming off of it. I need to find a wiring diagram. Will hunt later today but have a high profile job to machine first.
    http://bullyztoyz.smugmug.com/Machin...78090126_KeaVa
    have fun
    i_r_
  • #129
    Sep 2006
    I_R_,
    Are you using any of the Mach brains? I've been looking at those. They are pretty slick.
    JAckal
    Everything is bio-degradable, if you run over it enough times with the lawnmower.
  • #130
    Registered keithmech's Avatar
    Nov 2006
    canada
    here is a break down of parts for the impact http://www.acetoolrepair.com/parts-b...-type-100.html
    I have a Dewalt for my impact driver.
  • #131
    Jul 2006
    I found the parts list, but not the wiring diagram. Still looking.
    Haven't played with mach system yet. Did read part of the manual. Looks interesting.
    have fun
    i_r_
  • #132
    Jul 2006
    Had a little problem with my y encoder last night. I was running a fairlly long program and I noticed the y was not repeating position. It was an engraving with the z stepping down on multiple passes. It looked like it drifted off by about .03". Then on the next pass it was about .1 off so I stopped it. Part didn't move.
    I opened the control and it was hot inside the cabnet. I didn't feel the motor to see if it was hot. I'll try to get my cabnet fans running tonight and try it again.
    i_r_
  • Page 11 of 13 FirstFirst ... 8910111213 LastLast
    1. Lagun 3-Axis Retrofit
      By millnturn in forum Knee Vertical Mills
      Last Post: 09-24-2010, 02:28 PM
    2. VMC retrofit Z axis assist?
      By wyobmf in forum General Metal Working Machines
      Last Post: 12-30-2008, 11:01 AM
    3. Need Help!- 3 axis mill retrofit
      By beezerlm in forum Mach Mill
      Last Post: 03-20-2008, 10:36 PM
    4. BP S1 Z axis retrofit
      By CNC OT in forum Bridgeport and Hardinge Mills
      Last Post: 09-05-2007, 04:42 PM
    5. x2 retrofit x axis question
      By h_2_o in forum Benchtop Machines
      Last Post: 02-03-2006, 12:15 PM
