Results 1 to 3 of 3
Thread: monitoring / resetting faults via rs232
    Nov 2007
    i couldn't find an easy way to monitor and or reset a drive that faults using the rs232 connection. is there a way to do this?
    i have a nice Usb -> 8 serial box that i have hooked up to all 4 of my drives. I'd like to add something into Mach to monitor and allow me to reset the drives without using extra hardware (leds, switches, I/O)
    are there any hidden features of the drives?
    Feb 2007
    canada
    You can reset the drive via serial with the 'X' command. You would need to connect the Fault out to a input pin of your BOB to see when there is a fault.
    But you can't gang the RS232 RX and TX lines together on multiple drives. You would have to make a multiplexer circuit or use multiple serial ports.
    Larry K
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Nov 2007
    right, I have a separate port for all of my drives
    can you include a fault status as a firmware revision?
  1. CNC machine monitoring
    By CBNDude in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-29-2011, 07:46 AM
  2. Need Help!- CNC Machine Monitoring
    By basilpaulose in forum CNC Machining Centers
    Last Post: 12-29-2011, 07:40 AM
  3. Miyano BNE tool monitoring??
    By Bridged in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-14-2009, 12:47 AM
  4. TM1 faults
    By f1jdm in forum Haas Mills
    Last Post: 01-10-2008, 06:22 PM
  5. Options for resetting faults on R2020
    By mecheng10 in forum Servo Drives
    Last Post: 05-06-2007, 09:02 PM
