Results 1 to 2 of 2
Thread: Gecko G540 and Mach 3 Spindle control
    Oct 2008
    I have Mach 3 running a G540 driver and also using it to control my VFD. I have something real weird happening, the Output from the G540's VFD Out is nice and stable until 61% duty cycle. From 61% to 69% the voltage is real erratic and the VFD jumps all over the place. As soon as the duty cycle hits 70% everything smooths out fine.
    Example: Mach says it's outputing 63%, the VFD is jumping back and forth from 56% to 66% really fast. Any other Duty Cycle range beside the 60's is perfect.
    I thought it was the base frequency that needed to be raised or lowered but it has not made a difference. I have mine set at 50hz currently.
    Any clues or ideas?
    Richard
    Feb 2008
    Hi Richard,
    I've a G540 and Chinese Spindle.
    Sorry cant help as Im not at this stage yet. Im still just trying to turn the darn thing on. Any chance you can post some of your setting? I've just followed this tutorial.. but no luck!!..can you see what missing from this one?
    http://seafurymike.dyndns.org:2001//...=hf-spindles-2
    Brad.
    www.spidey4fun.com
  1. Newbie- mach 3 won't run motors w/ Gecko g540
    By Super Coffee in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 01:37 PM
  2. Is it possible? (G540 spindle control)
    By fretsman in forum Gecko Drives
    Last Post: 10-13-2009, 07:27 PM
  3. Spindle Control Through G540
    By john1285 in forum Gecko Drives
    Last Post: 09-30-2009, 11:26 AM
  4. Gecko G540 and Coolant Control Relay
    By MrAR15 in forum Taig Mills & Lathes
    Last Post: 07-10-2009, 10:01 AM
  5. Has Anyone used G540 to control spindle speed on the X2?
    By Waldermac in forum Benchtop Machines
    Last Post: 07-01-2009, 02:27 PM
