Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 02-06-2010, 09:04 AM
Monkey King's Avatar
Monkey King is on a distinguished road
CNC Lathe made by Monkey King
I plan to create vertical gang lathe.
Total length will be 800mm
Linear slide by HIWIN 15mm with AC Servo motor.
Ballscrew dia 15mm pitch 5mm
Headstock 3-jaw chuck will be 3"
Spindle speed 5000rpm
I already start 1 week ago, by turning & grinding the headstock spindle.
Here I do Internal turning.
Finish Spindle, next week do drilling
Old 02-07-2010, 06:39 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
I will follow your thread with interest, Monkey King. "Gang lathe" is something that gets my attention. And that is an impressive boring bar you have too.
Randy
Old 03-01-2010, 07:55 PM
Finally, I can do the headstock.
http://i813.photobucket.com/albums/z...g/P1020487.jpg
Old 03-01-2010, 09:15 PM
Enraged is on a distinguished road
looks very nice. did you cast the headstock, or bore it to that size?
FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
Old 03-02-2010, 09:45 AM
The headstock made by cast iron, boring and finish by grinding.
Old 03-06-2010, 08:51 AM
Today I do the bottom of Z body.
See the picture, total length is 800 mm, weight about 120kg.
http://i813.photobucket.com/albums/z...g/P1020575.jpg
Old 03-31-2010, 07:39 AM
Here is the riser block, will be put under headstock.
Old 03-31-2010, 10:37 AM
fatal-exception's Avatar
fatal-exception is on a distinguished road
That's some fine turning you've done there Monkey King! I can tell you enjoy doing it. I predict that your new lathe will be a work of art.
Take care,
Paul
Old 04-06-2010, 08:22 PM
Here is the middle parts between z axis & x axis.
as size reference, 1 ceramic tile = 30 cm.
Old 04-08-2010, 02:41 PM
Size estimation of the gang lathe.
  #11   Ban this user!
Old 04-08-2010, 02:54 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Wow, that is a serious lump of metal you have there.
Nice design.
Regards,
Mark
www.wrathall.com
  #12   Ban this user!
Old 04-26-2010, 07:06 AM
Today I finish the Z Body.
What country are you from?? CNCadmin CNCzone Club House 6 07-27-2010 07:54 AM
Just IN- Heavy Duty and Oil Country Lathes Big Lathe Guy Want To Buy...Need help! 0 10-14-2008 03:13 PM
The state of society in this country cdlenterprises CNCzone Club House 0 04-27-2007 07:54 AM
