Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 12-26-2009, 11:16 PM
roger_e is on a distinguished road
xand y axis out of alignment
I own a minitech mill....and it seems the x and y axis are out of alignment..it can't be the indicators..I used 2 diferent ones.
When I get the table square with the head on x the y is no longer square with x.....
Do I need to be taking the whole thing apart?
BTW...I have been machinig for awhile so squaring stock is not new to me...
Need Help!- minitech axis out of alignment roger_e Benchtop Machines 3 12-27-2009 06:46 PM
Parallel axis alignment Yovav Mechanical Calculations/Engineering Design 6 08-26-2009 04:45 PM
Need Help!- X2 X-axis binding, alignment christofer Benchtop Machines 3 04-27-2008 07:52 PM
5 Axis Alignment Tazzer AjaxCNC Control Products 5 02-25-2007 03:31 PM
x-axis alignment FLUTE HEAD Vertical Mill, Lathe Project Log 2 07-10-2005 10:05 AM
