Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 57
Thread: Grizzly G0602 10x22 Lathe Conversion
    Registered Steelpolish's Avatar
    Nov 2009
    Hello Everyone -
    I am new to this forum, but after looking around I decided to convert a lathe to cnc control. I need a small lathe for semi-production work, so I choose a Grizzly G0602 lathe to convert. My plans are to convert it to ball screws, three phase variable speed spindle, and an automatic tool changer turret. Mach3 is what I am going to use to control it all.
    Here are some pictures of the new lathe:
    Attached Thumbnails Attached Thumbnails Grizzly G0602 10x22 Lathe Conversion-hpim0942.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0943.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0944.jpg
    Nov 2009
    Electronics I am using:
    Xylotex Drive Board
    (2) 425 oz.in. Nema 23 Stepper Motors
    PMDX-122 Break-Out Board
    PMDX-171 Hall Effect Sensor (for spindle index)
    CNC4PC C6 Variable speed control
    Fuji AF-300 Mini Variable Frequency Drive
    Dayton 3 phase Motor
    I got everything wired up and tested on the bench today. It all seems to work good. Next is mounting the motor and waiting for my ball screws to come in
    Attached Thumbnails Attached Thumbnails Grizzly G0602 10x22 Lathe Conversion-hpim0945.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0960.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0971.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0949.jpg
    Aug 2006
    Looks like you are already off to a great start... Those are some nice quality parts and a great machine choice to boot. Good luck with everything and thanks for posting!
    Nov 2009
    Spindle speed question -
    Today I installed the 3 phase motor, and started to calibrate the spindle index signal. The signal is within 25 rpm of the called for rpm from Mach3 - Does anybody know if this is close enough for accurate cnc threading?
    My ball screws came in today, so hopefully I will get those installed soon.
    Work has started on the turret changer based on the design posted elsewhere on this forum. I am using a hirth type of coupler instead of dowels however. Enclosed pics are of the progress.
    Attached Thumbnails Attached Thumbnails Grizzly G0602 10x22 Lathe Conversion-hpim0970.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0975.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0982.jpg   Grizzly G0602 10x22 Lathe Conversion-hpim0983.jpg
    Registered SpeedsCustom's Avatar
    Sep 2006
    Yes, I like this thread already! Keep it coming!!!!
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Nice start. I have been eyeing up once of these lathes also. Can you fit the Z motor within that threading gearbox housing?
    What space is available under the cross slide for a backlash free X axis ball nut? On my 7X1 2conversion, I have a little Roton ball screw for X, but haven't installed it cause I'd need a second nut and anti backlash widgit, and dont have space for them.
    The commanded RPM is not used for threading in Mach 3 (or EMC, or TCNC), and would not be accurate enough for threading with these low powered machines.
    For threading, Mach will read the spindle index pulse, and thus know the actual RPM. It then adjusts the the Z axis speed each time the indexer pulses to maintain sync .
    You can increase the resolution by providing multiple pulses per rotation, as long as one pulse is twice as long as the others, and a minimum pulse width is maintained, then Mach works out for itself how many pulses per rev it is getting.
    Mach has a speed correction (look up table ) function where you tell it the actual speed verses commanded speed for four speeds per pulley setting. Say 200 RPM commanded gives 220, Mach then interprets an S200 like a S180 so that the actual speed is set about 200. It interpolates within the speed range.
    Regards,
    Mark
    www.wrathall.com
    Registered Crevice Reamer's Avatar
    Mar 2008
    Hi Steelpolish. Welcome to the Zone!
    Congratulations on choosing a good lathe. You seem to have a lot to contribute, and I'm looking forward to following your build.
    I have one reservation though--Your choice of driver/motors. The Xylotex will not hold up to any kind of production use, and the 91V 425s are seriously underpowered at 24V. My choice would have been G540 (Which has the C6 function & charge pump built-in and is unkillable), Keling 381s and 48V PSU.
    When the Xylotex dies, get the G540. That and a 48V PSU will allow your 425s to work a little better.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Nov 2009
    RotarySMP
    There is not enough room in the gearcase housing to mount a stepper motor unless you do quite a bit of modification inside of it. You would have to shave off the center casting that hold the gear shafts, and bore into the casting about 1/4 of an inch to fit the motor.
    The space under the x cross slide is 1.16" wide x 1.08" high. I am planning on shaving a bit from my ballnut to fit it in.
    My question on the spindle index is its bouncing around a little bit. When I command it to spin at say 750 rpm, the actual speed will show 745 - 760 and bounce between those numbers a bit. It will never at any speed show a single constant number. Is this normal, or should it show a constant number all of the time?
    Mar 2004
    Vienna, Austria
    Thanks for the reply on the gearbox housing and X ball nut space. What ball screws have you chosen?
    I use Turbocnc, any my knowledge of Mach is theoretic, as I have been considering changing to it.
    Having RPM fluctuations within a 2% band does not sound to me like it is a problem. It will depend on what you are trying to make, but I doubt that a <2% error on a thread will be noticeable for most practical applications.
    If you try to make a 4 foot long lead screw for an telescope mirror polishing machine, then it is probably unacceptable.
    Regards,
    Mark
    www.wrathall.com
    Nov 2009
    Crevice Reamer
    Yes, I am a bit worried about the quality of the Xylotex driver. I might be switching to some 350 oz servo motors driven by Gecko G320's. I have two other mills using steppers, and I am liking the idea of a closed feedback setup using encoders for this lathe. We shall see........
    Nov 2009
    I am using the 20mm ballscrew for the z axis, and the 16mm for the x axis purchased from homeshopcnc.com. They seem to be good quality.
    I was hoping the threading will be accurate enough. My main threading is 3/4 x 10 tpi, which is a pretty forgiving pitch size.
    A telescope mirror polishing machine? You never know...... LOL!
    Mar 2004
    Vienna, Austria
    I like the work you are doing on that turret. Keep the great photos coming.
    Regards,
    Mark
    www.wrathall.com
  • Page 1 of 5 1234 ... LastLast
    1. Grizzly G0602 10" x 22" Lathe Conversion
      By derekbackus in forum Vertical Mill, Lathe Project Log
      Last Post: 02-22-2013, 12:48 AM
    2. New Grizzly G0602 10x20 Lathe
      By twehr in forum General Metal Working Machines
      Last Post: 02-08-2013, 11:15 PM
    3. Build Thread- Grizzly 10x22 lathe, and X3 CNC conversion build log
      By TacPyro in forum Benchtop Machines
      Last Post: 05-06-2009, 01:30 AM
    4. G0602 Lathe conversion
      By SmoggyTurnip in forum Benchtop Machines
      Last Post: 03-05-2009, 09:54 PM
    5. Need Help!- New G0602 10x22 cuts a taper
      By rwskinner in forum Mini Lathe
      Last Post: 10-31-2008, 06:34 PM
