Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 11-23-2009, 06:35 AM
veteq is on a distinguished road
Sharing my new design
Hello people,
Just wanted to share 1 off my new designs,
Made over a 100 designs, biggest problem is maching the parts that are used to build the machine, man thats expensive.
regards,
Roy.
Name:	Kopie van mill 2.jpg‎
Old 11-23-2009, 06:41 AM
beliefdrive is on a distinguished road
great look
b.r
Old 11-23-2009, 09:17 AM
Starleper1 is on a distinguished road
This looks very similar to Jason3's Mill
Old 11-23-2009, 10:06 AM
rowbare is on a distinguished road
Wow! What a nice clean design. Wouldn't that make a wonderful table top mill for jewelers?
I wonder what it would look like with sliding chip covers as used on many VMCs instead of bellows. Something like these: http://www.cnczone.com/forums/showpo...4&postcount=83
Old 11-23-2009, 10:28 AM
Hey Starleper,
How are you doing, is you`re VMC still going strong?
Remember we had a pretty direct discussion about the frame connections through bolts and the open design in your thread.
Did it worked out for you, would like to know if you had any problems with chatter etc.
Have to say the endresult sure looks nice, wish i was at that stage with my machine.
It is just like all the VMC concepts, just like arie`s Beagle and Justin and yours VMC.
Only difference is that this machine is a lot smaller, table is only 230 x 135 mm. The outer dimensions off the machine are 500 x 500 x 500 mm,
( so 20 x 20 x 20 Inch ). The L-frame is only 200 mm wide ( 8 Inch )
Spindle diameter is 30 mm with a max. endmill off 6 mm.
Complete machine is made off Epoxy Granite, also the connection between y and x axes.
Allready have 3 Kuroda GP1002 c3 preloaded spindles, 12 THK HSR12P wagons and 6 rails and the NSK NR3060S main spindle with Maxon 250watt motor, all new through ebay.
Think this will be the final design, only have to do some face milling and tapping some holes for the rails etc. I dont have any machine over here so i have to pay all the machining and that costs a LOT!
Had bought a China spindle but i`m not happy with it, same for machined parts from China for another design i made. (price for the parts was great, paid and then they told me the extra cost for shipping, Man that was a lot, happy they refunded me the initial money)
Kind regards,
Roy
Old 11-23-2009, 10:31 AM
YEAH,`that would be great, tought off it but there is no room for it on the machine, these from gortite would be great to:
http://www.gortite.com/bellows/gordillo.html
Would have to find an extra Job for it....!!! LOL.
For a Jewelery it would be great since it has a high speed spindle (25000RPM) XYZ is 200 X 125 x 85 mm.
Weight around 65 KG.
Been looking on ebay for 3 years now, total price will be around 3K euro incl controller etc.
all new products with high precision, BLDC`s etc. Will be great, only costs a lot off time and patience to get it perfect.
Old 11-23-2009, 11:09 AM
Some more machine porn..
The goal is to pour the epoxy in 3 moulds, the inserts will stick out for 4mm.
The epoxy with inserts is then placed on a mill and faced flat and (parallel for y x) then drilled and tapped in the right pattern.
The upper and bottom frame will be bolted on a JIG on there inserts and then glued together with Moglice DWH310FL wich is designed for this stuff. After that i bolt everything on and align and it has to work...?!? Connection between rails and frame will be glued the same way to make good transfur off forces.
ID:	93858   Click image for larger version
ID:	93859   Click image for larger version
ID:	93860   Click image for larger version
ID:	93862   Click image for larger version
ID:	93863   Click image for larger version
ID:	93864   Click image for larger version
ID:	93866   Click image for larger version
ID:	93867   Click image for larger version
Old 11-23-2009, 11:35 AM
Originally Posted by veteq View Post
Hey Starleper,
Kind regards,
Roy
I'm good. The Mini VMC is pumping out parts like a champ. There are a few things I'd like to revise when I have time. Mainly the spindle.
I don't really have any chatter issues. I still want to make up some polyurethane mounts to sit it on. I still have a long ways to go before I can call it a VMC.
I'm back and fourth on ATC designs, I still need to make an enclosure, which I changed my mind on about 5 times so far.
My big thing right now is making a new spindle. Keep your eye out for a new thread appearing soon on my spindle build.
~Scott
Old 11-23-2009, 11:45 AM
\I still have a long ways to go before I can call it a VMC.
~Scott
It is a VMC it aint a horizontal milling center.
Spindles, i dream spindles (heard that before...)
Would love to design 1 myself, but i dont dare...
Would be nice to make a good thread about it, are you going to machine yourself of bring the design to a machine shop?
Was reading your thread a few seconds ago and had a laugh about the hole discussion. Nice to read a not personal forum. (not).
Old 11-23-2009, 09:30 PM
Ha I don't dare to pay someone to do something I know I can do my self. I already have the spindle itself partially made I just need to make all the housings and extra goodies that go along with it. It's going to be an R8 spindle with spring washers and a custom pneumatic cylinder.
I'm debating weather I want to stick with the wimpy X2 motor or go with a Servo.
  #11   Ban this user!
Old 11-24-2009, 12:52 PM
You have to buy a BLDS from kelinginc for cheap, there are nice BLDC drives on ebay for cheap without step/direction but then analog.
  #12   Ban this user!
Old 12-08-2009, 04:08 AM
Herbertkabi is on a distinguished road
Nice draws! But again and again this upside-down Y axis!
My opinion is that Y axis must to be turned contrariwise - rails up and wagons down - then you´ll get useful and long milling table wheres milling area always on the centre. At that only like that you can use 4-th axis in fyture (rotary table and tailstok).
Regards,
Herbert
Sharing my LCD install to 93 VMC15 FastFieros Fadal 9 10-18-2009 11:38 PM
Need Help!- Encoder signal sharing staffshome General Electronics Discussion 16 06-11-2009 11:32 PM
Newbie- Mastercam art sharing cnc metalcraft Mastercam 1 02-18-2008 07:22 PM
Info sharing SPEEDRE CNCzone Club House 2 12-23-2006 01:03 PM
Sharing Cad/Designs/G-Code!! bill south G-Code Programing 1 08-23-2005 09:41 AM
