Page 1 of 4 1234 LastLast
Results 1 to 12 of 44
Thread: Metal Gantry Mill
    Registered Zach_G's Avatar
    Jun 2005
    Metal Gantry Mill
    I've had this project on the backburner for what seems like forever, just waiting to get all my ducks in a row. Money, time, tools and space always seem to somehow conspire against my efforts but rather than build something with partial dedication, I've waited for the planets to align. Still a few more months to go before I have access to some tooling and can delve into construction but in anticipation I've been hammering out the final design. I'd like to share some ideas and ask questions.
    The goal is to end up with a medium sized bench aluminum cutting cnc with some ferrous capability as well. Travels will be X 18" Y 11" Z 13" and rapids of roughly 400 ipm. Spindle is a modified R8 mini mill with a 2 HP treadmill motor. I've already cut down the casting and welded the mounting tabs. Motion control will be with Mach running Zeta4 stepper drives. It's to be seen whether the parallel port will be sufficient or a USB interface of some sort. X and Z steppers are 1200 oz-in nema 34's wired up in a T connection, which will provide performance half that between parallel and series. I got dyno results from Lin Engineering and used them to model the acceleration characteristics of the X and Z. Not too bad for moving 260 lbs! Also assumes the Z axis will be counterbalanced, probably with a pair of gas springs. Will probably limit speeds to 400 ipm and I doubt I can program these acceleration characteristics into mach, and will probably have to settle for a constant acceleration which will result in a linear speed curve with slope equivalent to optimal speed curve at the highest feedrate i want to use. Still should be plenty fast
    I don't have any data on the Y motor. Just a round frame nema 34 which I've been told it's around 300 oz-in, but that should be ok for moving the relatively light head along the Y axis.
    Linear bearings are 25mm for the X and 15mm for the Y and Z. Plan on ordering precision rolled ballscrews from the Chinese ebay seller linearmotionbearings2008. 20mm for the X and Z, 15 for the Y.
    As for the structure of the machine, the bed is an 8x28 replacement bench mill table. The two vertical columns are 2.5" square pre-ground steel bars. the rest of the fabrication is surplus bought 3/4" flat ground stock. I plan on waterjetting this stock on a 5 axis machine to get zero taper on all the reference edges with non critical edges getting a low quality cut to save machining time and cost. The couple local shops I called said this should be feasible but I'd like to know what some of ya'll think. Also would like to know if it's possible to have the hole locations "punchmarked" by the waterjet to be finished on a drillpress later (I don't have a mill anymore and would like to avoid using one as much as possible).
    In the end I'd like to have the whole thing mounted on an enclosed bench with flood cooling containment and have the controls mounted under the table.
    Well that's probably enough for now, I'll leave the questions to be answered or asked. I'm pretty confident about the design so far, but feel free to fill my head with doubt
    Attached Thumbnails Attached Thumbnails Metal Gantry Mill-gantry.jpg   Metal Gantry Mill-mechanics.jpg   Metal Gantry Mill-bridge.jpg
    Mar 2008
    Zach,
    I see a major problem here: inertia. You said the gantry weighs 260 pounds and you want to move it at 400ipm. That is a lot of energy. What does the table weigh? Unless the table is firmly secured to a very sturdy bench or attached to a large piece of steel/granite it will dance all over the place.
    If you can get this sorted out it looks to be a very solid machine. Nicely drawn as well. What CAD program did you use?
    Good luck, keep us posted,
    Serge
    Registered The Blight's Avatar
    Sep 2006
    Denmark
    Is there a reason as to why you cant make the gantry stationary, and move the table instead? I know it will fill a bit more, but you wouldnt have to move so much mass around. Like this machine:
    I would also make a larger mounting surface for the two columns. Maybe a triangular shape to reduce the momentum arm? I know it will block the path of the Z axis, but if the plate extended behind the column, you would have plenty of room.
    I believe I still have a picture of your first design. Has been a great source of inspiration for some of my machine design projects. Never had the time to build any though.
    Edit: Beautiful drawings!
    Aug 2006
    UK
    Very nice drawings, but as others have said, I'd believe you'd be much better off accelerating the table and fixing the gantry - and if you really do have 130+kg of moving mass, you're going to need to anchor the machine to something much,much heavier (250kg+ IMHO).
    I'd also suggest that if you can find a way to be able to adjust all the mounting blocks for those linear carriages while the machine is fully assembled, but without its guards, you will have a lot less trouble aligning everything.
    Looks like an interesting project - best of luck!
    Feb 2009
    Quote Originally Posted by digits View Post
    My hunch is that we have seen the sum total of this project in those drawings. It seems to me that a benchtop mill you can buy for 1000.00 would do the same job.
    Jun 2005
    Thanks everyone (less our Larry the Cable Guy impersonator) for the feedback.
    Serge, appreciate calling me out on the inertia. In the quest for bridge ridgidity, I agree a solid footing was overlooked. And since everyone else seems to agree, I can't argue. The best solution I can think of then is... a bigger table. Internet search didn't yield any luck in sourcing just a table. Will call some local machine tool repair shops Monday to see if there might be a used bridgeport 9x42 or equivalent. Any other suggestions appreciated. BTW this was done in Inventor, I also use SolidWORKS occasionally since it has simple CAM/FEA plugins available.
    Blight, that's really cool someone recognizes my work! The goal with a moving gantry was to keep things light, since I move every 3-4 years. Good point on the small column attachment. My stock of 3/4 plate dictated material usage and that connection got compromised. I'll redo it.
    Digits, I've been keeping assembly and alignment in the back of my head throughout the design, should be doable.
    And if Larry can find a bench mill with similar travels for 1k, I'll concede defeat.
    Oh, obligatory shot of the pile of parts:
    Sep 2006
    Denmark
    Lucky!
    Feb 2009
    Quote Originally Posted by Zach_G View Post
    There was a nice Sieg Super X 3 that sold on e-bay for around 1000.00- ball screws, cnc etc.
    Forget the treadmill motor- even if you ever got this thing built that thing would last about 24 hours.
    I'll mark my calendar to check back in 6 months and see how far you've gone.
    Registered LeeWay's Avatar
    Jun 2004
    I don't know about that particular treadmill motor.
    I have been using a couple of them. One nearly every day almost all day for almost a couple years now. No issues at all. These are just about the simplest type of motor you can have. Not alot can go wrong. Bearing failure and a shorted wire is about it. Lots of guys have used that same motor without issue.
    I think this will be a great project and I look forward to following it's progress.
    Lee
    Registered SpeedsCustom's Avatar
    Sep 2006
    Where can I buy that exact treadmill motor! They no longer have them on Surplus!
    I like your design, but like everyone has said. I agree on on having the table move, lots of mass to move around. You will be happier with the quicker table.
    Nice project.
    -Jason
    Jun 2005
    Apparently you can buy it from me in 6 months, but it will only last you 24 hours... ;P
    I did manage to snag one of the last few, but similar ones do show up on ebay from time to time.
    Aug 2007
    good start
    I have been working on a similar design. I think that the bridge mill has obvious geometric advantage over the typical c frame. I agree with the others that the weakness is in the leverage at the base of the mill. I think you design can be tweaked to overcome this. too add stiffness to the bridge in the x direction you can move the bearings to the bridges rear and add a triangle support as i think has been suggested. it would also be very helpful to extend the length of the base of the bridge, at the expense of some travel to gain better leverage. the second weakness is bridge flex in the y direction. It will flex like a parallelogram. Without four sets of linear rails at the base you cant count on stiffness in the y direction from the bottom. What you can do is add material on the outside of the bridge so that the stiffness comes from the top of the structure. it should resemble a giant C clamp. If you can stiffen the bridge i am confident your machine will have no problem with steel. I also think 400ipm is more than you will find useful on this size of a machine. if you can achieve 150imp that should be plenty. Good luck, Ben
  • Page 1 of 4 1234 LastLast
    1. Gantry mill retro fit
      By lv2ryde in forum General Metal Working Machines
      Last Post: 09-12-2007, 03:25 PM
    2. YAG-M: Yet Another Gantry mill
      By nash in forum Mechanical Calculations/Engineering Design
      Last Post: 11-24-2006, 11:38 AM
    3. Gantry VS. C frame for metal mill
      By Tristar500 in forum General Metal Working Machines
      Last Post: 11-21-2006, 06:48 AM
    4. CI gantry mill
      By i_am_fubar in forum CNCzone Club House
      Last Post: 09-13-2006, 10:38 AM
    5. My New Gantry mill project
      By Stevie in forum Vertical Mill, Lathe Project Log
      Last Post: 08-05-2006, 05:58 AM
