Results 1 to 3 of 3
Thread: milling
    Aug 2009
    milling
    Hy guys I would like to know what would the best matel to use, to machine knive for a earth haugger to drill holes in ground for wooden posts. I do not want to have them tempered rockwell. Sorry for my engliche cause I am french.
    Thank you Luigi
    Banned
    Jun 2009
    united states
    Quote Originally Posted by Luigi2 View Post
    Thank you Luigi
    Hot roll Steel would be your cheapest and would do just fine, or stainless that's what mine is made out of. Most of the ones I've seen are steel. Hope this helps.
    Aug 2007
    Hard Facing welded onto the cutting tip will help it stay sharp and reduce wear. The Hot Rolled Steal that CNCJUNKY makes note of will work fine as you will need a strong but flexible type of steal.
    We all live in Tents! Some live in content others live in discontent.
  1. Offset Chain Milling vs Path Milling
    By ynnek in forum TurboCAD/CAM
    Last Post: 03-11-2009, 06:29 PM
  2. CNC MILLING
    By mmurning in forum Employment Opportunity
    Last Post: 11-13-2008, 12:06 AM
  3. PCB Milling
    By itsme in forum Hobby Discussion
    Last Post: 08-27-2008, 03:53 PM
  4. Need Help!- NPT Milling
    By jybute in forum Haas Mills
    Last Post: 08-14-2008, 03:19 PM
  5. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum CNCzone Club House
    Last Post: 06-30-2008, 10:23 AM
