Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 08-14-2009, 11:21 AM
sethyrish is on a distinguished road
chinese spindle on brass or steel?
Hi. I’m new to this forum and CNC and have read various threads about the Chinese water cooled spindles but are still unsure as to whether you can use these spindles on metal harder than aluminium as most people are using them on wood. I want to do some work on brass up to 6cm including drilling holes of less than 1mm and I was attracted by the 0.005mm run out and the quietness. I’m contemplating either getting an X2 or making a mill using a CNC’d compound table bolted to a right angle frame with the spindle mounted on a “Hiwin” linear rail system. I thought I ask for people’s opinions of this idea.
CHINESE SPINDLE 2.2KW Ed Williams Open Source CNC Machine Designs 65 04-26-2012 01:01 PM
Best laser for marking stainless steel, brass, etc. art2009 Laser Engraving & Cutting Machines 15 09-21-2010 02:39 AM
Chinese Spindle Experiences analogman DIY-CNC Router Table Machines 27 12-02-2009 05:37 AM
Need Help!- 0.6mm Brass / Copper on 0.4mm Steel Backing mariuscarstens General Metalwork Discussion 2 11-10-2008 08:13 AM
steel to brass connection DisgruntledUser Mechanical Calculations/Engineering Design 24 01-12-2006 07:41 AM
