Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 07-24-2009, 01:07 AM
Bhautesh is on a distinguished road
Spindle Type
Hi Everybody,
I have started designing a new VMC but i got confused about which type of spindle to use?
can anyone help me in this?
i want to know different types and advantages of spindles.
many manufactures uses HSK A63 but what it means?
What are the advantages of that?
Old 07-25-2009, 02:14 PM
Bhautesh, HSK 63 is originally a German specification. H hollow, S short, K taper. 63 is the diameter of the flange, 63mm.
This is a good spindle nose because the taper has full contact with the internal taper of the spindle nose. Also, the flange is pulled against the spindle face. Consequently, the HSK system is more rigid than other taper type system such as NMTB, ISO or MORSE tapers.
The HSK system is also a good high speed system. They are generally balanced for high speed machining as well.
This system is a bit expensive. You will have to decide how rigid your spindle really must be and how fast it will be rotating.
Hope that helps, Dick Z
DZASTR
Old 07-27-2009, 01:59 AM
Thank you for this reply
I got this point.
Spindle bearings on a bridgeport type machine zoeper Bridgeport and Hardinge Mills 9 01-05-2009 05:49 PM
Replacing Spindle Motor on Prototrak type mill mgb1974 General Metal Working Machines 0 07-02-2008 06:29 AM
spindle type xinzc28 Benchtop Machines 0 06-29-2008 11:08 AM
Anyone cutting wax/metal with dremel type spindle? sendkeys General Metalwork Discussion 0 03-29-2006 12:27 AM
J-Type head spindle bearings? GalaticDan Bridgeport and Hardinge Mills 3 01-15-2006 08:36 AM
