Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 06-21-2009, 11:02 PM
RP Designs is on a distinguished road
Vari-speed head spindle encoder
I am looking to add an encoder to my spindle to be able to do rigid tapping. The mill has a vari-speed head and packaging constraints make it difficult to attach anything directly to the spindle for speed and position measurements. I am looking for a simpler way to attach an encoder to the spindle. I have thought about using a hall effect pick-up and either attaching a toothed wheel to one of the pulley halves, but do not know how well that might work and whether that would be accurate enough or not. Has anyone else added an encoder to the spindle of their vari-speed head? Would you mind sharing how you set it up?
TIA
Old 06-22-2009, 03:34 AM
spindleservice is on a distinguished road
Hello,
right! could add it by a toothed wheel and then add the encoder to it. As encoder Lenord+Bauer or a Sensor of VS-Sensorik (located in Germany). Then L+B offers also a small test device to adjust the values correctly. The run-out of the toothed wheel should be adjusted lower then 5µm. The toothed wheel is also available at L+B with mostly 256 tooth.
spindleservice
Old 06-22-2009, 07:09 AM
emader is on a distinguished road
You don't mention what type of cnc controller you have and whether or not the cnc has the capability to do rigid tapping. The spindle drive amplifier must also be capable of providing full torque to near zero motor speed (should be a full vector type ac drive).
If your system has the capabilities, it is also best to use a quadrature encoder attached directly in some way, to the output shaft of the spindle.
If you don't have these capabilities, then you could be throwing away good money.
Good luck,
Ed Mader
President - EMR, Inc.
Old 06-22-2009, 01:23 PM
Originally Posted by emader View Post
Good luck,
Ed Mader
I will be running an AjaxCNC centroid control which does have a Rigid Tapping option. I will be adding a constant torque VFD as well. My main difficulty is packaging really.
Swapping Step Pulley For Vari-Speed... HimyKabibble Bridgeport and Hardinge Mills 25 02-15-2011 01:44 PM
Belt Replacement vari speed jlv3901 Bridgeport and Hardinge Mills 3 07-24-2007 07:25 AM
Please help with vari speed! AbleGear Bridgeport and Hardinge Mills 2 06-04-2007 04:49 PM
HF 8X12 Vari-speed Ed Boysun Mini Lathe 13 03-06-2007 04:03 PM
2 hp to 1.5 hp motor interchange on vari-speed head?? wdbdel Bridgeport and Hardinge Mills 5 12-15-2005 09:34 PM
