Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 06-20-2009, 08:12 AM
contactirfu is on a distinguished road
From CNC router to now a DIY VMC
HI folks -
Just got the below on the used market sales - both ball screws are pretty good and give 12 inch of actual motion. The slide below gives me a work around for 125mm.
so guys let me kno on which axis should I put my slide on - ????? on the Y or on the Z axis.
I have 3 Nema23 Sanyo denki motors(old ones) with a Hobby CNC controller and will go with a 1:3 reduction on this - and that will get a lot of torque on them I think!
The idea is to use laser cut parts for a bolted / welded structure.
will use a ER16 collet extender for the spindle and a 1 hp motor with VFD for the speed control.
The design is to start with modelling of the ball screws and the slide I have -
its basically a long term project - probably a year to 2.
it will certainly help me in getting done so many of my Alu parts for the things I am planning to make!
RGDS
IRfan
ID:	83170   Click image for larger version
ID:	83171   Click image for larger version
Tags
diy vmc, irfan
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 10:48 AM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
