| Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines. |
#44
| test fit of Y axis there were isues with the tapered dowel pins as to possible turn then in to bolt holes so there is a 4 bolt pattern like a 4 bolt main bearing on a big bolck engin\e also did not have a taper dowel pin reamer i mean how much stuff do you need? |
#45
| Y axis assemblie used vbx bearings roton ball screws 3/4 dia I turned the ball screws on a lebond lathe with a carbide tool bit turned the ball screw down to 15 mm for the vbx bearings then cut it to 14 mm for threads lathe dident have metric so used 20 threads per inch as the coarser the thread the deeper you have to go you will see more pic in X axis |
| Mill/Drill conversion coming right up! | balsaman | Vertical Mill, Lathe Project Log | 214 | 04-29-2009 08:04 PM |
| Square Column Mill/Drill Conversion | Jay Kyle | Vertical Mill, Lathe Project Log | 14 | 08-23-2005 01:42 PM |
| Harbor Freight Mill/Drill Conversion Log | Halfnutz | Vertical Mill, Lathe Project Log | 31 | 04-13-2005 10:56 PM |
| First Impressions for CNC mini mill conversion | CNCadmin | General Metal Working Machines | 4 | 11-16-2004 08:37 PM |
| Converting a Mill/Drill to CNC | NeoMoses | General Metal Working Machines | 3 | 02-04-2004 03:29 AM |
