Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 05-22-2009, 07:27 PM
hassjb is on a distinguished road
Vertical mill cnc update
I have an Excello 602 with 1.5 volt 20 amp slo-syn stepper motors. The motors are omnipolar I believe (6 wire). I want to control the machine with a laptop and wondered what I would need between the laptop and the motors. I'm thinking of using an interface for 3 stepper motor drivers and the computer. That should also take carre of my power supply but what kind and or size drivers will I need and is there anything else to be added? If you have any ideas it would be a great help....Joe
Iduma Vertical Mill industrialmach Want To Buy...Need help! 0 05-01-2009 09:26 PM
Go-Well vertical mill Matt130 Benchtop Machines 0 08-14-2008 02:09 PM
Need Help!- I am purchasing a HF 12 x 36 and HF vertical mill DrDudley Want To Buy...Need help! 6 07-02-2008 04:00 AM
Kent KTM 380 vertical mill keitholivier Knee Vertical Mills 2 08-06-2007 04:40 PM
Best Vertical Mill? bvandenb Haas Mills 11 04-20-2005 05:47 AM
