That's a really nice skid - it must be a decent size Heli
What grade is the steel stock you have? You could use the pieces vertically, and fix the headstock between them, linear rail on each one and Z axis ball screw between...?
1-2-3 blocks: I use mine pretty much daily! I don't have a surface plate, but would be lost without the blocks. I use them for all sorts. Sometimes if I need to machine all sides of a part I tap the back and bolt the block to it, then clamp the block in the vice. I bolt them together for a small, accurate square. Yesterday I used them to support the ends of a long bar held at the centre in the vice. They would be approaching the most used tool in my 'shop, I'd hate to be without them...
Those renderings are from Rhino!? I have a lot to learn... How do you get the nice reflection on the background? Very cool...
Best regards,
Jason
