Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-17-2009, 02:11 PM
hesham morsy's Avatar
hesham morsy is on a distinguished road
machin origin ????
Hi to everybody
anybody know the origin of these machines
thx
ID:	77894   Click image for larger version
ID:	77895   Click image for larger version
ID:	77896   Click image for larger version
Old 03-17-2009, 02:13 PM
HuFlungDung's Avatar
Moderator
Originally Posted by hesham morsy View Post
Hi to everybody
thx
Top right hand corner? What do I win?
Old 03-17-2009, 02:43 PM
Al_The_Man's Avatar
I say bottom Left
If there is no specification plate on them, I would suspect they are custom made one-offs?
Old 03-17-2009, 03:32 PM
2 reply by 2 Moderator oops do i Look Suspicious
Old 03-17-2009, 06:04 PM
Al_The_Man's Avatar
Maybe you rate top attention.
Old 03-17-2009, 07:18 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
Hesham, those are neat looking little machines. Did you take the photos? The four photos are obviously taken in the same room. I would much appreciate some higher-resolution pictures if they are in your posession.
It looks like the machines have tubular steel frames, obviously bolted together. Extruded t-slot plate for the table, like Isel. From the orientation of the axis drive motors, it looks like the drive is rack-and-pinion with the racks being machined from a round bar that also acts as a second bearing for the axis. The guide bars and racks (if so) are mounted in sub-blocks at each corner that are adjustable to make the X-Y plane parallel with the table surface.
It looks like the machines are prototypes or small production. In the orange machine, the corner blocks are secured on the sides of the corner tubes, and in all the others the blocks are secured on the face of the tube. The green and white machines have older round-body stepper motors, and the blue and orange machines have more recent square-body motors.
Do you have any more information on the machines that you can provide?
Randy
Old 03-17-2009, 07:30 PM
zephyr9900's Avatar
No, I think I was wrong about the axis drives. They are probably leadscrews. On the blue machine, there is a motor mounted on the back. Could there be leadscrews on both sides of the frame that are chained/tooth belted together to drive the gantry from both ends? The motor on the side of the gantry would be the Y-axis motor. Whatever, they look to be very nicely made machines.
Randy
Old 03-17-2009, 07:57 PM
hi Randy
their no rack-and-pinion just 2 acme screw slaved to the x axes
the rest is ok
i find the photos here actually i am looking for photos or info
http://ftp.cnchungary.com/Varsanyi_P...fotok/a1-2.jpg
http://ftp.cnchungary.com/Varsanyi_P...20fotok/a2.jpg
http://ftp.cnchungary.com/Varsanyi_P...20fotok/a3.jpg
http://ftp.cnchungary.com/Varsanyi_P...20fotok/a4.jpg
Old 03-17-2009, 08:58 PM
zephyr9900's Avatar
Hi Hesham,
Ask Peter Varsanyi about the photos. (click on "Klikk ide" on that page to send him a message). The photos are in a folder of his at an FTP site for apparently http://www.hobbycnc.hu . Thanks for the links! There are many impressive homemade CNC machines there!
Randy
Old 03-19-2009, 03:10 AM
Peter Varsanyi is on a distinguished road
Smile CNC pictures....
I don't have more information about the pictures....
Here more pictures....
http://www.ftp.cnchungary.com/Varsan...gepek%20fotok/
  #11   Ban this user!
Old 03-19-2009, 03:23 AM
thx man for fast reply
im
DIY Plastic Injection Machin Bread_O Moldmaking 13 09-18-2011 02:09 AM
Need Help!- communicate machin to machine doggerbite Mori lathes 0 02-18-2009 10:18 AM
Stock Origin stang5197 Mastercam 4 03-13-2007 11:36 AM
Origin and mazak?? Fendertok Mazak, Mitsubishi, Mazatrol 1 12-12-2006 06:06 PM
Origin trouble JOE65 Yeager Automation 0 02-14-2004 11:57 PM
