Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 03-16-2009, 03:52 PM
stenberg is on a distinguished road
Proxxon MF70 cnc conversion.
Hi!
This is my first post on this forum.. I've been reading alot here and on a few other forums about cnc conversions and the theory around the procedure.
I know that you should never go for starting a new thread as your first post on any forum but I think this is the best way to get help for problems with my particular project.. if someone is even interested.
This is my first CNC-project!
So to the business:
I'll be starting with a stock little micromill called "Proxxon MF70". It's designed and manufactured in Germany (not 100% sure about the manufacturing part these days but still..) so you can all figure out it's super quality machinery even though it's really tiny.
To get an idea of how small it is I'll start off by posting a picture:
That's a 1,5 litre bottle in the background and a 23mm carriage on the work table.
So as you all can figure out this thing is not intended for anything but tiny tiny pieces of work and I'm not expecting it to mill inconel super fast anyway
So for the intended modifications:
To start with:
-Some small nema 23 steppers around 0,5-1 Nm.
-Drivers? I've built a set of pminmo L297 drivers but thy will probably not be in use for long once I get everything set up and working.
-Ballscrews
-Tiny ballrails for the Y- and Z-axis (look at the pics)
-Mach 3
I do my CAD and CAM at school on UGS NX4 and SolidWorks/CamWorks 08
This is what I have to start with:
A ballscrew setup for the Z-axis and a linear module that will be the base for a new X-axis/work table. The stock MF70 table is in the pic too for comparison. The new linear module is about 20mm wider than the stock one but the Y-travel will be even a bit better with the new one because of the new y-rails that will be ordered. X travel=250mm.. around 10".
A few steppers:
I've also ordered an ATC package from USOVO in germany! + a tool lenght sensor plate, a tiny precision vice and some bits here and there. I'll post some pics of these once I get them.
I hope atleast someone is intrested in tiny machines like mine!
EDIT: I found a nice little video on youtube showing the tool changer:
Old 05-01-2009, 03:49 AM
rumblfmp is on a distinguished road
Stenberg,
these minimills are fun. A nice way to make small parts for model trains etc. but just too small for RC controlled models. I've been thinking of buying one of these at the "intermodellbau" fair I visited last week. Proxxon had a 10% discount on the machine and usovo was also at that fair with their ATC kit.
Almost bought one, even if only to play around with the tool changer, I really want to know how they do this.
Rob
Old 05-01-2009, 03:26 PM
veteq is on a distinguished road
nice small mills
Thats a nice machine,
cool toolchanger, what do you want to mill in the future???
I`ve looked at the machine a iew times but desided to design my own.
travels are xyz 160/100/80 mm, goal is to make some nice rc car parts.
keep up the good work and post some nice milling videos when its ready.
regards
Old 05-07-2009, 12:57 PM
Thanks for the feedback!
Some more drastic changes have been made to the plans now..
I'm going to use a base made of polymer concrete aka. epoxy granite and design the machine similar to a Hermle gantry style 4-axis machine in this manner:
I will be using two (either 15mm or 9mm THK as i have both options on the shelf) linear ball slides on each side on the x-axis and a total of 8 carriages for that single axis combined with a 20mm ball screw in between. The most problematic with this design is of course figuring out a light but super robust design for the gantry beam. I will be posting some drawings soon..
Most parts of the proxxon will be used in this thing too, just not as parts they were originally designed for. As an example, the z-column will be used as a cover for the spindle and motor.. It will be really small so no worries about that
Old 05-07-2009, 05:29 PM
Thumbs up
Phew,
that's not a drastic change, that's a CNC builders dream
Your text says 4-axis, I guess you mean 5. Curious to know what you mean with 'really small', 5-axis machines tent to be fairly big compared to the size of the spindle. I would guess that for an MF70 size spindle the size of this machine will have a footprint between 60x60 to 80x80 cm.
Still very small for such a machine. Have a look at my big monster (we now call it "Elanimal")
The table is 200 x 120 cm and the height below the gantry is 37 cm. I have been thinking of building a swing the same style as used on the Hermle to be able to do some smaller (ahem) 5-axis work.
But one of the problems is to get decent 5-axis CAM software. I am partly doing this as a job so all software has to have official licenses that are paid for ...
The more I think about it, the more fun it becomes to buy a machine like an MF70 for a 5-axis project. The nice thing is that I can use standard angular contact bearings found at a local junk yard: Just a few weeks ago I saw some bearing in the size of 20-or-so cm and was wondering where these big bearings are used. Perfect for a 2-axis tilt/rotation table.
Keep us posted. I can't want to see the SolidWorks drawings.
I have some questions about the design of the tilting control: are you planning to use a gear style drive as on the Hermle or will you use a belt?
What is a proper resolution of the angular movement? With 1.8 deg. steppers and a 1::3 ratio you get a 0.6 deg resolution (or 0.0375 deg when using 16 microstep drivers). At 5 cm away from the centre this is a 0.5 mm (or 0.03 mm) movement. My current 4th axis uses a standard rotary table with worm drive giving me 800 steps per degree - this is a bit of an overkill and it means the system is a bit slow (29 deg/second).
Regards,
Rob
Old 05-07-2009, 06:37 PM
The initial plans are to not build the fifth axis at this stage but just have a belt driven 4th axis rotary table on one wall driven with a large stepper or a servo if I find some cheap ones. To start with I will be running turbocnc which doesn't support a fifth axis, until I start figuring out how EMC works. There are some nifty five axis projects running on EMC and code is available for a poor student like myself.
The point in moving the linear slides up on top of the frame is getting as large an area for the total movement with as small total machine dimensions as possible. I will be needing just an extra 45mm + the max radius of the mill bits to be used (I believe 5mm is the largest ER 8 collet available.. or at least the largest I own) around the initial maximum travel area as the spindle package will have the x-y dimensions 90x90mm.
I've been thinking about sizing it to be mounted in a sturdy 19" aluminium rack similar to a server rack cabinet - to give an idea of the size of the machine.. a travel area the size of an A5 piece of paper would be enough for my purposes.
I just got my first 3 litre epoxy kit too so i can get started testing various mixtures. I've ordered a few different other brands too.
I could throw in a picture of my first 5 minute sketch from a few weeks ago which had some design features poorly suited for my needs:
(the spindle mount is around 160mm offset from the Y-axis slides even if it looks like it was just next to the back wall)
Just imagine the X-axis linear slides on top of the sides on the frames and the Y-axis column bolted to the X-axis' carriages.. also notice the colouring
The angular resolution needed will be determined by the size of the maximum size of the raw material to be machined which is still to be figured out while I search for cheapo, usually second hand, parts.
//stenberg
Old 05-07-2009, 06:55 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
John Deere! I like it. Just the color for all the back-and-forth roughing passes.
I like your concept, stenberg. I have been thinking of taking the Proxxon I've been using as high-speed spindle on my Tormach machine, and making a mechanism for it. Your size and sturdy concept are perfect for me also. I'll watch your development with interest.
Randy
Old 06-04-2009, 11:52 AM
I've gotten hold of a set of Bautz linear servos with power stages and stuff so this thing could become a really fast one when I start getting somewhere.
I've also bought a compaq rack server to control the thing running on Ubuntu and EMC now. It's a nifty old computer with hardware RAID, SCSI harddrives and stuff so it should be quite perfect for this kind of operation.
I've also gotten my dial indicator and other measuring equipment so I can start lining up linear slide packages for the concrete casting.
Drawings are still on their way
Old 07-10-2009, 09:14 AM
Crappy picture, I'm out of space on the forum gallery
First row from the top:
Remote with MPG wheel to the left, 3x Jetter/Bautz linear motors. Under them are a bunch of Wallac linear motor power stages, custom made for the motors.
Second row:
Furthest to the left is a piece of magnetic railway for the motors, the blue PCB's are BLDC 3-phase driver cards (I love the concept of design reference parts). The green ones are power supplies custom made for the power stages.
Bottom of the pic:
Martzis USB HID Interface. Some random 24V power supply and a bunch of magnetic rails wrapped in newspaper.
Those are the new new toys I'm still waiting for a bunch of power supplies, encoders and a 19" rackmounted chassis for everything.
Old 02-08-2010, 08:21 AM
Ron Thompson is on a distinguished road
Hello stenberg,
Pardon me for any errors, as I don't usually use this forum.
I was searching for info on the Martzis USB HID Interface, and I found your post.
I looked at the schematic and it appears it is all inputs. Is this so? I am looking for a way to get outputs from Mach3 over USB.
Thanks,
Ron Thompson
  #11   Ban this user!
Old 02-08-2010, 02:01 PM
Hi, Ron
Yes, the MUHI is indeed an input-only interface board. It supports up to 64 digital inputs, four encoder counters (not fast enough for servo drives) and four analog inputs.
I think you´re looking for a "SmoothStepper".
/Tobias Stenbeg
  #12   Ban this user!
Old 02-08-2010, 02:19 PM
Yes, I am looking for the functionality of the smooth stepper. I'd like to build it, though.
I am interested is using an Arduino, or at least something in the avr family that can drive motor drivers, relays and accept inputs from switches via USB. I am not interested in duplicating the parallel ports with usb. Ideally it would function with steppers or servos/encoders.
Ron Thompson
Proxxon MF70 iceblu3710 Benchtop Machines 1 06-18-2008 01:18 AM
Help for a first small cnc PROXXON MF70 nisma Benchtop Machines 0 04-22-2008 04:38 AM
Need Help!- PROXXON MF70 GeoCasa Benchtop Machines 2 03-11-2008 12:32 PM
Problem- PROXXON MF70 GeoCasa General Metalwork Discussion 0 03-08-2008 07:22 AM
proxxon mf70 cnc fidia General CNC (Mill and Lathe) Control Software (NC) 0 10-28-2007 11:44 AM
