Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: Watch lathe CNC conversion
  1. #13
    Feb 2006
    I loosely mounted the Z rails until I install the X platform. I will be working on that next. I have about 20 holes to drill in it to mount it so the Z axis and also to mount the X rails. I installed longer screws on the ends of the rails to prevent the trucks from running off and loosing all those ball bearings.
    Vince
    Attached Thumbnails Attached Thumbnails Watch lathe CNC conversion-z-rails.jpg
  2. #14
    Feb 2006
    X axis
    I started on the X axis cross slide. I ordered some precision ground flat stock. It was +-.0001". After I cut it, it curled up to where the ends were now .0004" low and the middle was .0004" high. It took me almost 4 hours of scraping to get it back to flat +-.0001". I cut a groove down the center (before I started scraping) with a 5/8" ball end mill to made room for the Acme nut. It did not warp any after the groove which surprised me.
    Vince
    Attached Thumbnails Attached Thumbnails Watch lathe CNC conversion-x-axis01.jpg   Watch lathe CNC conversion-x-axis02.jpg
  3. #15
    Registered zephyr9900's Avatar
    Feb 2006
    That's looking really good, Vince. I like your end stops. Did your X axis plate warp from parting off the end of a piece of barstock, or did you cut the long side(s) too?
    Randy
  4. #16
    Feb 2006
    The X axis carriage piece was cut off the end of the flat stock, the sides were not cut.
    I cut the ball slides for the X axis. It turned out they were hardened and the only way I could cut them was with a peanut grinder and an abrasive wheel. I mounted them on the carriage to see how they would fit. I found when trying to adjust the Z axis ball slides parallel, even .0002" would cause the carriage to bind a little. It took a lot of adjusting to get is just right. Of course I will have to do it all over again since I have to take it all apart to get the motor mount supports attached to the lathe bed.
    Vince
  1. Anyone done a C6 lathe conversion
    By mcraig79 in forum Mini Lathe
    Last Post: 11-13-2008, 05:38 PM
  2. My CNC Lathe Conversion
    By acondit in forum Videos
    Last Post: 10-17-2008, 11:20 PM
  3. PC 200 CNC Lathe Conversion
    By ERL31 in forum Australia, New Zealand Club house
    Last Post: 06-15-2008, 03:56 AM
  4. Lathe VFD conversion
    By GMill7 in forum General Electronics Discussion
    Last Post: 03-28-2008, 05:36 AM
  5. CNC lathe conversion (again, sorry!)
    By kong in forum General Metal Working Machines
    Last Post: 03-27-2004, 02:06 PM
