Results 1 to 4 of 4
Thread: Slant bed lathe Z axis 4 way load rails?
    Apr 2007
    New York, NY
    Im planning a lathe maybe slant bed. For the Z axis do I need 4 way loading rails (THK SHS, HSR) or can I get away with "horizontal" loading rails (THK SSR, SR)?
    Registered Jason3's Avatar
    Aug 2007
    New Zealand
    Thumbs up
    For a horizontal axis where the main force is directly down through the rails, the SSR type actually offers greater rigidity than the SHS (or HSR) type of an equivalent size. As soon as the axis is not horizontal, or the forces are acting from other directions, the SHS or HSR type are better.
    If you possibly can, go for the caged ball type - SHS or SSR - not so much for the longer life, but they move MUCH more smoothly, and can really help your surface finish and accuracy.
    Best regards,
    Jason
    Apr 2007
    New York, NY
    thanks for the reply. I didn't know that SSR/SR was more rigid than SHS/HSR. good info
    Aug 2007
    New Zealand
    Well, only fractionally There's some interesting reading here: http://www.thk.com/documents/us_pdf/...chmodel_cb.pdf
    I liked the example of a durability test with an SHS type caged ball system - it still looked ok after 30,000 Km travel, with only an initial lubrication.
    Amazing stuff...
    Jason
  1. Y axis rails sharing the load?
    By johnmac in forum DIY CNC Router Table Machines
    Last Post: 09-24-2008, 10:59 PM
  2. slant bed lathe?
    By clovenedhoof in forum General Metal Working Machines
    Last Post: 08-27-2008, 03:04 AM
  3. MAZAK Quick Slant 30N 4 Axis CNC Lathe
    By ISHY in forum General Metal Working Machines
    Last Post: 08-24-2008, 04:05 PM
  4. Slant-bed lathe question
    By zephyr9900 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-07-2007, 08:57 PM
  5. What's the advantage of a slant bed lathe?
    By Splint in forum General Metal Working Machines
    Last Post: 07-24-2007, 10:59 PM
