Well, the machine is now in the garage. Had to remove the spindle motor to fit under the door opening.
The machine has a smaller panel on the back where the old 3-phase power entered. It contains the ON/OFF switch, three fuses, some sort of over voltage or under voltage relays???, etc. Can I gut this entire box? My new setup will be 220V single phase to a Hitachi VFD. Power coming in is controlled with a sub panel breaker, and the VFD has an on/off button.
Should get some pics tomorrow once I get the garage warmed up...
LinkBack URL
About LinkBacks
