Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > General Metal Working Machines > Vertical Mill, Lathe Project Log
Vertical Mill, Lathe Project Log Post your project building or converting logs here for lathes or milling machines.
Old 01-02-2009, 04:09 PM
LN-JET is on a distinguished road
Moving column benchtop mill
I started my ramblings almost one year ago in this thread: http://www.cnczone.com/forums/showthread.php?t=50256
Since then I have made some decisions, cut some steel, and bought some stuff, and I will make this a new project thread. Still don't hope for very frequent updates. This is going to take time!
Steel parts will only be spot welded, to avoid stress releiving, and then filled with epoxy/granite.
I got the 20mm rails and all 12 carriages from Marchant Dice today. That was the first cash spent:-)
Regards
Lars
Cnc newbie
Pics: 1.The final layout in cad, used to make laser cutting files.
2. Checking parts for fit, and starting to weld pieces together.
ID:	72733   Click image for larger version
Old 01-02-2009, 05:20 PM
hedgehog23's Avatar
hedgehog23 is on a distinguished road
out of this world. very cool.
Old 01-04-2009, 09:49 PM
hesham morsy's Avatar
hesham morsy is on a distinguished road
so far so good
did you intend to put some enforcement ribs before the epoxy/granite
Old 01-04-2009, 11:02 PM
dannystooblue is on a distinguished road
how much do you expect it to cost to build? What kind of motors and drives do you plan to use?
Danny
Old 01-05-2009, 05:19 AM
Hesham: ribs; maybe if they are needed to get the top surface flatter.
Danny: Very hard to estimate cost, but as an alternative to buying a X4 with accessories, I am prepared to use up to $5000. Depending on spindle solution etc.
I am looking at the Cnc Brain for control http://www.safeguardrobotics.com/def...x?tab=cncbrain,
and glass scales for closed loop operation.
The machine has provision for 34 size motors. Torque not decided, but in the area 600-800oz/in.
Rather than adapting the build to parts scrounged from ebay, I rather use the time to save for new equipment.
I was planning to do this build in spare hours at work, but as it looks, there will not be many of those:-(
Lars
Old 01-05-2009, 06:10 PM
Lars
I have mixed emotions about used vs new. I have a few Pacific Scientific motors I picked up on ebay for less than $50 each, each with an encoder and pulleys rated in the neighborhood of 880oz. To drive them I picked up slo-syn 7 amp stepper drives for about $60 each. I think if you watch long enough there will be something come through ebay that is an unbelievable deal for excellent quality.
Tell me about the composite that your filling the thing with, buying it prepackaged or mixing it up your self?
Danny
Old 01-06-2009, 01:24 AM
Danny
Of course you can get high quality parts if you wait around long enough. I have no problem buying used.
I will propably use the 1100 resin with very slow hardener, from R&G http://shop.ezentrum.de/4DCGI/ezshop?hid=27&sprachnr=2,
and just fill with blasting sand and small pebbles , up to 4-5mm size.
This is for dampening, so stuctural strength is off less concern.
Lars
Old 01-21-2009, 08:39 PM
muddobber76 is on a distinguished road
Very cool!!, don't see alot of horizontal builds on here. I would like to build a horizontal one day if I ever finish my vertical.
Old 01-22-2009, 03:26 PM
Pr. definition I think this is a vertical mill, as the spindle will be mounted upright.
Not much progress yet. I have just ordered the epoxy, 13kgs should do it?
Best thing is that we have a large DEA cmm machine at work, and I am being trained on it this week. It will be a great help when it get to aligning rails and axis.
Lars
Old 11-06-2009, 05:00 PM
Long time no posting on this one:-(
That i mostly because I was given some ISEL linear components for free, and decided to build a 2'x2' router which is now almost finished.
Here is the progress I have made since january:
Filled it up with sand and small rocks & slow epoxy. By weight the epoxy is less than 10% of the mix.
I have mounted a 3mm x 20mm strip of steel to reference one of the rails on both x an y-axis to. Then I milled the rail mounting areas flat, and milled the reference ledges 90 deg to each other.
This is mostly how it has been laying around since then. The base went from 43kgs to 108 after filling, and feels like solid rock..
Most of the hardware is on hand. 900oz/in motors, ball screws, support bearings etc. I also bought a chinese 2.2kw spindle and VFD that might be used.
I am presently building a control box that I will use on the router to begin with. It contains a 70V power supply, Smoothstepper, 4 Gecko 203's, Homann DC-06 speed control for the VFD. I will also have a separate 5 and 12volt power supply and the VFD it self in there.
Lars
  #11   Ban this user!
Old 11-06-2009, 05:18 PM
After I tack welded the base together, I noticed that I had got the top upside down.. No problem other than that I have to update the drawings.
Good thing it isn't a house that I'm making:-)
Lars
  #12   Ban this user!
Old 11-08-2009, 10:33 AM
Eson's Avatar
Eson is on a distinguished road
Nice work! Keep going!
travaling column mill wayneman General Metal Working Machines 1 11-04-2008 06:41 AM
Mill Column Mods digitalmdj Shopmaster/Shoptask 8 03-29-2008 08:11 PM
Knee Mill vs Square Column Mill HimyKabibble Bridgeport and Hardinge Mills 0 11-09-2007 06:27 PM
Round column mill SCROMAL General Metalwork Discussion 1 06-18-2006 12:23 PM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 10:24 AM
